block heater question
Old Nov 16, 2013 | 11:35 PM
dennis11's Avatar
dennis11
When I plug in the block heater on my 2002 PS the coil light which I have assumed is the equivalent of the wait to start light on my 1997 PS does not go off as quickly as the wait to start light in my 97 when it is plugged in. Is the heater in the 2002 not as heavy as the one in the 97 or is my entire assumption wrong.
Old Nov 17, 2013 | 12:24 AM
DHamSTER's Avatar
DHamSTER
The block heater element could just be old and tired. They do have a certain number of hours on them before they don't heat as well.
Do you plug in at the same time, and do you plug them in on the same days?
Old Nov 17, 2013 | 03:11 AM
90pioneer's Avatar
90pioneer
Get a coolant temp gauge and it will tell you exactly how warm it is
Old Nov 17, 2013 | 05:56 AM
Tugly's Avatar
Tugly
Mine died a coupe of years ago and I had to replace it... so these have a life expectancy.
Old Nov 17, 2013 | 09:19 AM
Ponyboychris's Avatar
Ponyboychris
My opinion is the wait to start light isn't the most scientific instrument to measure the health of your block heater. You need to measure either the water temp (not using the stock gauge but an accurate aftermarket one that goes below 100 degrees) and/or measure the output of the heater itself when plugged in. Also the difference between the superduties and OBS CPU's can also be the reason for the differences you are noticing in the wait to start times. Just too many variables to say if your heater is working or not.
Old Nov 17, 2013 | 09:41 AM
Firefighter 1406's Avatar
Firefighter 1406
Would you check the coolant temp in the resivor? To check for this?
Old Dec 11, 2013 | 02:08 PM
maadman's Avatar
maadman
I may be out in left field again but the "block heater" shouldn't have anything to do with the glow plug's WTS light. You're talking apples and oranges, engine coolant and combustion chamber heat. Right?
Old Dec 11, 2013 | 04:35 PM
DHamSTER's Avatar
DHamSTER
Yes the block heater heats the block and the fluids in the block for a quicker fire. The glow plugs are more for the combustion. So yes apples and oranges.
Old Dec 11, 2013 | 05:44 PM
HKusp's Avatar
HKusp
The WTS light is an idiot light. It doesn't stay on longer or shorter based on any information from the temperature.
Old Dec 11, 2013 | 07:29 PM
t.scottNDU's Avatar
t.scottNDU
+1. From what I gather the WTS or coil symbol is merely there to assure you that your truck does in fact have glow plugs. Whether they're actually working or staying on is another story.
Old Dec 11, 2013 | 08:39 PM
KH85's Avatar
KH85
x3. Without a coolant temp gauge you should be able to feel heat from the motor after being plugged in all night. I would highly recommend you install an LED light on your GPR wired into the cab so you know exactly when your glow plugs are on and how long they are on. The wts light in dash is 100% useless.
Old Dec 11, 2013 | 10:09 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Assumption wrong.
Just throwing numbers out there, but run a NAW4 PCM in your 1997 and then put a TDE1 PCM in it after you get used to the "wait to start" light operation.....there is a HUGE difference between those two calibrations as far as the "wait to start" light is concerned and they're completely interchangeable with each other. The 99-03 trucks are also mapped completely different to your older truck in that regard.
It's possible to change the mapping so the "wait to start" light mimics the actual glow plug relay energized time (not that anybody would ever need that.....)
Old Dec 12, 2013 | 01:44 AM
dennis11's Avatar
dennis11
Block Heater
Maybe there is little difference on my 2002 but on my 97PS the WTS comes on and shuts off in 2-3 seconds when the truck is plugged in and conversely when it is not plugged in it takes up to 7-8 seconds to turn off. This is in sub-zero weather....16 below zero a couple of nights ago. As I mentioned the difference is not as pronounced in my 2002PS when it is plugged in but there is a difference for sure. I feel that it is not apples and oranges but that there is a direct connection between the time the WTS is on and whether or not the block heater is plugged in on very cold nights. This is my experience but I appreciate every ones imput......Dennis11
Old Dec 12, 2013 | 06:51 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Engine oil temperature has a HUGE effect on how long the light stays on.
Old Dec 12, 2013 | 07:13 AM
Dan V's Avatar
Dan V
This....it's easy to see that there is SOME temp value being monitored when at -20 not plugged in the WTS lite takes forever to go out as compared to when it the truck is plugged in.
