ipr question
Old Nov 16, 2013 | 06:03 PM
lght1's Avatar
lght1
ipr question
hi
looking at my hpop before puting in new seals, i happen to notice that the ipr solenoid, the electrical connector part seems loose..meaning it moves a little bit back and forth sideways.
is this normal ?
Old Nov 16, 2013 | 06:32 PM
Yams's Avatar
Yams
Is the 3/4" nut missing or loose on the back side?
Old Nov 16, 2013 | 06:34 PM
lght1's Avatar
lght1
hi
no, the nut was there and tight...hand tight any ways
the solenoid does seems to have a little play in the barrel..not much. i suppose its normal.
Old Nov 16, 2013 | 06:47 PM
Yams's Avatar
Yams
Unplug it, take the nut off, pull the spacer off, then the coil off. The black part should be fixed in the brass colored sleeve with no movement.
Old Nov 16, 2013 | 07:10 PM
lhud's Avatar
lhud
The black electrical connector is attached to the bronze colored coil and will rotate about the shaft of the main ICP. Just make sure the nut is snugged up.
Old Nov 16, 2013 | 07:48 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes, the black connector is supposed to have some play.
Old Nov 16, 2013 | 07:53 PM
lght1's Avatar
lght1
hi
hmm..confused.
the plastic piece visible from above, has some movement inside the slot in the barrell.
even if the nut is uber tight....there is still some wiggle between the black connector housing and the barrel/bronze coil.
Old Nov 16, 2013 | 07:59 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
IT IS NORMAL. I dont know how much clearer you want it haha. The connector will always have some play. Even when new. The play in the connector and the nut are not related.
Old Nov 16, 2013 | 08:52 PM
Yams's Avatar
Yams
I have mine in my hand right this very moment. The way it's made is the coil is incerted into the sleeve, the sleeve is pressed by a machine to roll over the edge to hold the coil in the sleeve. It has very little movement, but it's not glued in the sleeve....
If the nut isn't tight enough it could vibrate loose and then the coil.. do what it wants.
5 to 10 lbs should be a good snugness.
Old Nov 16, 2013 | 09:07 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Hes not even asking about the nut or the solenoid...
lght1, sleep soundly tonight... The connector is supposed to wiggle a little.
Old Nov 16, 2013 | 09:15 PM
lght1's Avatar
lght1
hi
thanks for the info. there has been so much to do with swapping these engines..guess i am inventing things to worry about..lol
Old Nov 16, 2013 | 09:19 PM
Yams's Avatar
Yams
Yes he is....
hi
hmm..confused.
Pay attention once in a while.
Old Nov 16, 2013 | 11:14 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by Yams
Yes he is....
'Pay attention once in a while.' Seriously dude?
The connector in the solenoid is what he is asking about. That will move no matter what. He is not talking about the solenoid moving on the IPR shaft, or the nut moving, just the connector.
Old Nov 16, 2013 | 11:17 PM
lght1's Avatar
lght1
hi
yes..the connector. it doesn't move backward and forward...just a little slop sideways.
not sure if it was damaged or not.
nolan3387
Aug 24, 2013 09:01 PM
ReFlectiveMan
Feb 18, 2012 11:04 PM
bigrig62
Aug 25, 2009 02:40 PM
jrv7874
Oct 31, 2007 11:54 AM
