ipr question
Old Aug 25, 2009 | 11:55 AM
bigrig62's Avatar
bigrig62
ipr question
i was looking at ipr and the wiring connection that holds the soleniod to the ipr wiggles back and forth is this normal?
Old Aug 25, 2009 | 12:55 PM
Action4478's Avatar
Action4478
Was the 3/4 tin nut still there ?..
Old Aug 25, 2009 | 12:58 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
No, it's not. The wiring doesn't keep it connected, there is a "tin nut"the screws on to the end of the shaft. There is also a "spacer"... it's like a tube that keeps the sensor portion (where the wires attach) pushed firmly in to place, then the tin nut secures it all. Sounds like your tin nut came loose. Check in the valley of your engine for the nut & spacer.
Old Aug 25, 2009 | 02:40 PM
Chistoso's Avatar
Chistoso
Here is a link http://cw-diesel.com/LuxSite/IPRInfo.htm with info on the IPR.
