Going to replace glow plugs . . .
Old Nov 15, 2013 | 01:53 PM
1'stonraceday's Avatar
1'stonraceday
2001 F-350 7.3 w/145K.
Is there a such thing as a "better" glow plug? Or should I just go with the Motorcraft?
Old Nov 15, 2013 | 02:44 PM
cps's Avatar
cps
one word, motorcraft.
Old Nov 15, 2013 | 03:30 PM
HKusp's Avatar
HKusp
Yeah, don't do anything BUT the Motorcraft. Bosch and the others have been known to fail horribly.
Old Nov 15, 2013 | 06:29 PM
1'stonraceday
Excellent! That was where I was headin'.
Old Nov 15, 2013 | 07:28 PM
Tugly's Avatar
Tugly
More to the point - absolutely NOT Autolite.
Old Nov 15, 2013 | 08:35 PM
JAMSRF250's Avatar
JAMSRF250
OK so I just purchased a set of Bosch glow plugs for my 2001 7.3 F250. You guys are saying that only use Motorcraft. Can someone send me the part number for the Motorcraft plugs so I can make sure I get the correct one this time. Also is changing something a novice can do or should I hire it done. The biggest thing I've done on my 7.3 is changing the water pump. I like doing thing myself so I know whats done. Any advice would be appreciated.
Old Nov 15, 2013 | 08:45 PM
t.scottNDU's Avatar
t.scottNDU
ZD11 is the part number. They can be had at RiffRaff or dieselorings.com for a good price.
Here is a good thread to look at. Read over it! Will give you others things to look for and check while you're under the valve covers.
https://www.ford-trucks.com/forums/1...w-plugs-2.html
Old Nov 16, 2013 | 04:12 AM
Tugly's Avatar
Tugly
Rule 1: No need for keys in the ignition.
Rule 2: You're gunna scratch the paint - unless you actively prevent it.
Rule 3: The passenger side is less fun.
I am a light-duty mechanic/technician. Until I had this truck, my tools handled small stuff - no bigger than 3/4" or 22mm. Popping the valve covers is one of the easier jobs on the truck, but it really helps to have a few additional tools in your arsenal. 10mm and 13mm deep sockets with a universal, about 18" total of socket extensions, 13mm flex-head socket [LINK], and a piece of 5/16" semi-rigid plastic fuel line.
cjspack
22
Feb 2, 2013 10:34 AM
GreenballsFX4
Oct 24, 2012 09:14 PM
jbounds
Oct 21, 2010 06:27 PM
CountryDeisel
Jan 6, 2010 11:17 AM
chach3835
23
Jan 1, 2006 05:55 PM
