Sponsored by: Auxito
GEM Module
Old Nov 14, 2013 | 06:33 PM
lukebecker30's Avatar
lukebecker30
GEM Module
I just got my truck and during the test drive I failed to put it in 4x4. Well, Not working.
Took it to the Ford Dealership and they called me up saying its going to be about 800 bucks to fix the GEM module.
OUCH!!!!!!!!!!!
But after doing some looking, nothing else seems to be wrong with this truck. NO prob with windows, wipers or anything else. Just 4x4 doesn't engage.... (no dash lights regarding 4x4 ether).
I just hope that they really checked everything over before seteling on this. Fuses and stuff...
Anyone else run into this prob? Just need some rest assurances.
1998 F150 Leriat
Old Nov 19, 2013 | 04:39 PM
LxMan1's Avatar
LxMan1
Welcome to the forum. I have moved this to the proper forum.
The GEM module operates basically all electrical accessories. It is quite possible that the 4x4 circuit is bad.
Old Nov 19, 2013 | 06:38 PM
Bluegrass 7's Avatar
Bluegrass 7
Do some checking of your own.
When you turn the switch to 4H while setting with motor running do you hear a 'clunk'?
If no, can you confirm the transfer case motor runs to it's first position by sound and with some help?
What does the dash light do?
Does 4L work when properly switched to?
Does your windshield leak onto the GEM?
These questions are worth $800 to you if you will take the time to check them out and see if he problem is less than the GEM.
Good luck.
ddoty
1997 - 2003 F150
Feb 2, 2019 05:29 PM
1998f150stx
1997 - 2003 F150
Apr 17, 2010 07:42 PM
Ford4x4-JD70AB
May 22, 2006 10:42 PM
jwt5004
1997 - 2003 F150
Apr 15, 2005 01:48 PM
