Sponsored by: Auxito
GEM Module
Old Jan 31, 2019 | 01:01 PM
ddoty's Avatar
ddoty
GEM Module
Would a bad GEM cause the wipers to keep running after they are turned off? They were running on slow intermittent but have now began to run at the next to the highest speed. I pulled the fuse for now but if it rains I will be stranded until it stops.
Old Jan 31, 2019 | 05:00 PM
Bluegrass 7's Avatar
Bluegrass 7
It is possible.
I would first take the GEM out, inspect it for circuit board corrosion due to a windshield leak.
The control switch functions are 'high' impedance points on the GEM board and subject to corrosion 'leakage'
causing odd operations. This can also happen to 4x4 functions because they are all GEM controlled.
The stock switch signals. the Gem to operate the wiper motor in all it's modes as does the dash switch signaling the GEM for 4x4 operations.
Good luck.
Old Feb 2, 2019 | 05:29 PM
ddoty's Avatar
ddoty
GEM
Thanks for the advice This is something that I never ran into before. A new aftermarket MFS did not help and some say it may be the motor not going back into the park position. I just don't want to throw parts at it so I will inspect the GEM for corrosion. Hope that is a cure.
12valveEx
Apr 3, 2018 10:56 PM
tataylor
1997 - 2003 F150
Jan 19, 2012 08:14 AM
Power Stroke 7107
Nov 10, 2006 06:31 PM
jonshep
1997 - 2003 F150
Nov 1, 2004 08:57 AM
