Engine hours
Old Nov 14, 2013 | 09:40 AM
RKCORPS25's Avatar
RKCORPS25
Engine hours
Is there anyway I can check my engine hours on my 04 f250.
Old Nov 14, 2013 | 10:14 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
On my 05 if I press the odo reset button it will scan through the engine hours, mileage since last reset and to reset that, hold in for a few seconds.
Old Nov 14, 2013 | 10:17 AM
jswartz84's Avatar
jswartz84
The hours feature came out in 05. You might be able to have the dealer hook up to it and tell you. It might be worth a call.
Old Nov 14, 2013 | 10:31 AM
RKCORPS25's Avatar
RKCORPS25
I might have to do that do you guys know what all the diagnostics on the dash mean when I set it to run diagnostics
Old Nov 14, 2013 | 04:17 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Here's a partial list. I don't think it ever got update/added to. Can't fink the link to the thread.
Odometer Trick:
1.With the key in the ignition and in the off position press and hold the odometer / trip button.
2.Turn the truck to ‘On’ but do not start the truck.
3.After a few seconds the gauges will sweep from nothing to max, release the odometer / trip button.
4.The odometer should now read ‘GUAGE’, you are now in a information mode.
5.Start the truck
6.Now every time you press the odometer / trip button it will cycle through the information available.
7.When you shut the truck off the odometer will go back to showing mileage.
GAGE - Carries out gauge sweep of all gauges, then displays the present gauge values. Also carries out the check sum test on ROM and EEPROM.
All segments illuminated.
Illuminates all odometer segments.
bulb
Illuminates all micro-controlled lamps and LEDs.
r ####
Returns to normal operation of all micro-controlled lamps and LEDs and displays hexadecimal value for ROM level (used when requesting assistance from the hotline).
nr####
Displays hexidecimal ROM level and type as stored in non-volatile memory (NVM).
EE ##
Displays hexadecimal value for EE level (used when requesting assistance from the hotline).
dt ####
Displays hexadecimal code for the final manufacturing date.
###C
Gas engines display last temperature gauge input value from SCP, temperature gauge will indicate present temperature. Diesel engine displays present temperature analog/digital input in decimal as a ratio, temperature gauge will indicate present temperature.
dtc ####
Displays a 16 bit DTC in hexidecimal format. DTCs displayed are those detected in continuous operation not during self-test.
EnG
Displays English speed value being input, speedometer will indicate present speed.
m
Displays metric speed value being input, speedometer will indicate present speed.
tAc Displays the tachometer value being input to the instrument cluster. Tachometer will indicate present rpm.
FUEL
Displays the present analog/digital fuel level being input to the instrument cluster as a ratio.
OIL
Displays the last analog/digital reading of the oil pressure switch contact resistance, oil gauge will indicate present level.
br
Displays the brake fluid level in an analog/digital ratio value.
bAt ##.#
Displays present battery analog/digital voltage.
rhEo
Displays present hexadecimal pulse width modulation (PWM) dimming input.
rhi, rhS, rho
Alternating 1 second display of pulse width modulation (PWM) input duty cycle, SCP hexidecimal dimming step, output driver counts in hexadecimal.
Cr
RUN/START sense circuit check.
PA, Pb, PC, and Pd
Displays 8-bit hexadecimal value for the Port A, B, C, and D readings (used when requesting information from the hotline).
PE0-PE7
Displays 8-bit hexadecimal value for the Port E0-Port E7 in analog/digital readings
07-19-2007 | 04:43 PM
superv10
I have an 05 with the 3 buttons (Info, Setup, Reset)
You have to hold the Setup and Reset buttons at the same time, then turn key to on - you will see TEST and as soon as you do, let off the buttons and then start the truck - press reset to cycle thru all the options...
07-20-2007 | 12:42 PM
EZ-Ford
There also appears to have been a change when the went from the 1 line to 2 line Odometer display. Below are all the items that list on my truck (2 line display). I have added the descriptions, based on the previous information where it seems to fit. A few are still unknown. Specifically, the item listed as OIL, shows as all zeros (000) in my display. So if this is pressure as was previously, boy does that worry me (though my pressure gauges shows good). The numeric entry (on mine 001624), I don't know what that means or if it will be different with a different truck.
When you guys check yours, update this list below and lets see if we can put together a complete outline that can then be sticky'ed to a tech folder.
Display ..........Description
SWEEP GAUGES ..Full deflection sweep
ALL ...........Odometer segment check
BULB ..........Warning light check
PF #### .......
SF #### .......
001624 ........
KEY IGN # .....Ignition key-in status
ROM #### ......ROM level
NR #### .......ROM level and type
EE #### .......EE level
DATE #### .....Manufacture date
CF1 #### ......Configuration setting
CF2 #### ......Configuration setting
CF3 #### ......Configuration setting
CF4 #### ......Configuration setting
DTC #### ......Cluster diagnostic trouble codes
MPH ###.# .....Speed MPH
KPH ###.# .....Speed KPH
TACH #### .....Tach RPM
FUEL AD ### ...Fuel level ratio - ?
FUEL P ### ....Fuel level - ?
F INIT ### ....
C TEMP ### ....Coolant temperature degrees Celsius
ODOM ### ......Odometer input
OIL ### .......
BATTERY ### ...Charging system voltage
PWM ...........
DOOR 1 # ......Driver Door switch status
DOOR 2 # ......Pass Door switch status
SEAT BLT # ....Seat Belt status
CHECK ENG # ...
PA – PW .......Port Data
PAD0 – PAD1 ...Port Data
AD00 – AD17 ...Port Data
Old Nov 14, 2013 | 04:31 PM
big inch's Avatar
big inch
As far as I know, there is no hour meter in the '04-back trucks.
Old Nov 14, 2013 | 04:48 PM
npccpartsman's Avatar
npccpartsman
Will IDS not pull engine hours either? We discussed tools to read them on the earlier trucks but didn't come up with anything definitive.
Old Nov 14, 2013 | 04:54 PM
RKCORPS25's Avatar
RKCORPS25
Thanks for that info very helpful.
Old Nov 14, 2013 | 07:20 PM
big inch's Avatar
big inch
I don't recall ever trying, but I have never seen an hour reading anywhere in the available data.
It wasn't until 05 that Ford began asking for engine hours as a part of their prior approval process for certain warranty repairs. So, I would assume that they would have required it sooner had it been stored in the earlier trucks.
katiesdad7
Nov 6, 2009 06:18 PM
jdw1
Jul 30, 2009 03:57 PM
sandaholics
Aug 16, 2007 01:19 AM
wiingnut
Jan 23, 2005 06:49 AM
My4x4Toy
Nov 18, 2004 06:45 PM
