power steering and the cold
Old Nov 13, 2013 | 07:11 AM
Desarata's Avatar
Desarata
I could use some advice--before I start tossing money at the truck. A 1978 f150 4x4
Steering works just fine in warm weather--- but now that it's down in the 30's she's all over the road until I've driven about 45 min's
there is a little whine while cold / not when warm.
I'm running 10.50x15 tires no lift and every joint and connection in the front end except for the ball joints have been changed this in the last 6 months.
My best guess is the power steering pump but I would hate to replace that and find out it's the steering box.
what do you guys/gals think---should I just bite the bullet and buy a red top box and new pump ????
Old Nov 13, 2013 | 09:27 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
It probably has more to do with the tires than the steering. The BFG TA/KO's I'm running do the same thing. Even on my "new" truck (2002), PS will make a little noise till the fluid gets warmed up.
Old Nov 13, 2013 | 10:10 AM
psychlopath's Avatar
psychlopath
What fluid do you have in there?
Old Nov 13, 2013 | 01:02 PM
Roger Carter's Avatar
Roger Carter
Double check the tire pressures. Tire pressure will drop about 1 pound per 10* (F) temp drop. Low pressure can cause the problems you are describing.
Roger Carter
Old Nov 13, 2013 | 03:04 PM
Desarata's Avatar
Desarata
Red face only when cold
I'm using trans fluid and the tires are brand new (yesterday) coopers. this truck did this jan, feb of this year before I changed anything on the front end. And it's been working just fine until it got cold. I'm using the right fluid I think (ford transmission fluid)
I start to make a turn and steering acts like I hit a bolder in the road and it does this over and over again until warm (about 45mins of driving time) until then it's almost imposable to keep it in a lane.
just a update I've replaced all the ball joints (no Joy) next step a new steering gear (red top ) That should fix it '
unleashd
Jan 19, 2018 05:43 AM
DinoB
Jul 3, 2016 07:24 AM
hasteranger
Jan 23, 2013 06:31 PM
SuperDutyScaler
Nov 22, 2011 09:49 AM
browntown3
Feb 8, 2009 08:48 PM
