code speakers please help me break these codes!!!
Old Nov 12, 2013 | 07:43 PM
86351wHOsupercab's Avatar
86351wHOsupercab
So i do not have a check engine light but i have a edge programmer. I was goofing with it and pulled the following codes.
P0478
P1212
P0470
I am on my phone and mobile forum illiterate.
Thanks in advance
Dale
Old Nov 12, 2013 | 10:35 PM
bakerbuilttracks's Avatar
bakerbuilttracks
P0478 Exhaust Pressure Control Valve High
P0470 Exhaust Pressure Sensor Circuit Malfunction
P1212 Injector Control Pressure Not Detected During Crank
Sounds like you need to clean and or replace your EBPV and Tube.
The 1212 is you icp sensor which probably is bad. Pull the plug on it and look to see if you have oil in the connection. If so replace it.
Old Nov 13, 2013 | 07:59 AM
86351wHOsupercab
Thank you.
We got into the 30s last night and this old girl is one cold female dog. I dont think i let her warm up enough and she lost power and stalled. I need to do the GPs bad. I cleared the codes and the 1212 code has not come back.
As for the exhaust I dunno. It has after market 4" turbo back and not cat. It was on the truck when i bought her.
Why am i not getting a check engine light from these codes? The light does illuminate when you turn the key on.
diehardstroker
Feb 17, 2014 08:40 PM
awillo0406
20
May 7, 2013 02:58 PM
pjnadon
Jan 18, 2011 09:31 PM
King0581
16
Apr 18, 2008 03:46 PM
manasota
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 13, 2005 08:47 AM
