Sponsored by: Real Truck
Plugging in.
Old Nov 12, 2013 | 03:42 PM
ericl72's Avatar
ericl72
Plugging in.
I have a 2000 7.3 deisel. Truck was in Oregon and they didn't need to plug in at night. I live in the Midwest and I will need to plug in at night. What kind of heater do you reccomend? Thanks.
Old Nov 12, 2013 | 04:21 PM
Hotrod70d's Avatar
Hotrod70d
There should be a plug in the front bumper if equipped witha block heater next to drivers tow hook
Old Nov 12, 2013 | 04:34 PM
david0505's Avatar
david0505
Hi,pls check carefully,I've been told by Ford techs that some diesels were shipped without cords even tho the block heater was installed (depending upon destination)..Dave
Old Nov 12, 2013 | 05:38 PM
Chalkie's Avatar
Chalkie
I was told by my Ford dealer that ALL diesels came with a block heater. The cord was only there if the purchaser was paying for a heater.
They get you though if you go to get a cord, last I heard around $50.
Old Nov 12, 2013 | 06:10 PM
PSDlongbox's Avatar
PSDlongbox
this is correct. They all have the heater just not all have the chord. I am planning on finally getting around to doing the marine outlet mod in my front bumper this winter.
http://www.truckowners.com/content/2...eater-plug-mod
that's a quick write up if interested.
Old Nov 12, 2013 | 09:40 PM
Chalkie's Avatar
Chalkie
Further to this, you really don't HAVE to plug it in. Folks up in Canada can get by without plugging them in. I only plug mine in when the forecast is for below 0 temps. Otherwise it is just a convenience to get the truck to blow hot air faster, has nothing to do with getting it started.
Old Nov 12, 2013 | 09:47 PM
PSDlongbox's Avatar
PSDlongbox
yes it will start, but having the block heated puts less strain on the motor for even moderately cold starts. I have mine on a mechanical timer. I leave around 7am so it clicks on at 4am and turns itself off at 7. You don't need it plugged in all night just sucking juice.
Old Nov 14, 2013 | 10:46 AM
bbender85's Avatar
bbender85
the working condition of your glow plugs / GPCM will come in to play too... unfortunately i have codes on 6 of my 8 glow plugs, so i have to plug in when the temp gets into the 30's at this point.
Originally Posted by PSDlongbox
..I have mine on a mechanical timer. I leave around 7am so it clicks on at 4am and turns itself off at 7. You don't need it plugged in all night just sucking juice.
same here. i only run mine for 1.5-2 hours.
sully75
Feb 26, 2009 06:50 PM
Demolition
6.4L Power Stroke Diesel
18
Nov 1, 2008 08:49 PM
Brew Camper
Feb 2, 2007 04:10 PM
shendren
Jan 13, 2004 08:48 PM
FarmLaw
Jan 10, 2004 02:27 PM
