block heater problem,need help
Old Feb 25, 2009 | 01:52 PM
sully75's Avatar
sully75
I have a 1993 f350 7.3 and I plug in the block heater and it seems to be working but when you touch the truck you get shocked. The heater seams to be electrifing the truck. I checked the cord and I cant find any brakes in it. Whats causeing this?
Old Feb 25, 2009 | 05:55 PM
Don Senkow's Avatar
Don Senkow
Most likely you have a cord issue, somewhere. Even if the ground is cut off you still should not get a shock. Plug it in somewhere else, maybe you have an outlet problem, not likey though.....Don
Old Feb 25, 2009 | 10:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Sounds like a bad ground connection somewhere and a heating element in the block heater is leaking current to the heater.
Probably the element is getting ready to fry.
There should be no continuity from either of the flat blades on the plug to the truck body.
Old Feb 25, 2009 | 10:33 PM
ford trans tech's Avatar
ford trans tech
the good news is that they are still available
Old Feb 26, 2009 | 12:48 AM
sully75's Avatar
sully75
where can I get one and how much are they?
Old Feb 26, 2009 | 08:09 AM
Dean88's Avatar
Dean88
You can get the cord and block heater from O'reilly's. The cord is 13 bucks and the block heater is roughly 40 if I remeber. Make sure that the person you are talking to has an IQ above 50 because they have to look in a SPO book.
Old Feb 26, 2009 | 06:50 PM
Dave Sponaugle
NAPA stocks them as well.
bobcf
Jan 15, 2015 06:40 PM
Rusty_Old_F250
23
Nov 26, 2011 01:02 PM
Northbrook
Oct 19, 2011 07:28 PM
Mr. Andrew
13
Feb 11, 2009 09:29 AM
automaticj5
2004 - 2008 F150
Nov 17, 2006 09:27 PM
