map lights will not work
Old Nov 11, 2013 | 06:51 PM
djordan's Avatar
djordan
I have a 98 Exp and my lights on my heater controls as well as my map lights will not work.....All the other lights work fine Dome lights too....would anyone know what my issue may be I have checked all the fuses and they are all good
Old Nov 11, 2013 | 09:57 PM
alloro's Avatar
alloro
Does the instrument cluster illuminate? Is the dimmer switch turned all the way down?
Old Nov 12, 2013 | 03:03 PM
djordan's Avatar
djordan
cluster works fine and the dimmer switch is up as far as it can go with out turning on the dome lights
Old Nov 12, 2013 | 05:37 PM
Hamfisted's Avatar
Hamfisted
Did both map lights just all of a sudden stop working? I was going to suggest the bulbs might just be burned out. Takes a 579 bulb for the map lights.
579 bulb looks like this...
For the climate control backlighting you'll have to pry the surrounding trim piece off with your fingers (there's two tabs on top, two on each side, and two along the bottom...) and remove the control unit. Most of them take a tiny #74 bulb. I don't have the specific instructions for each unit.
-Mike
Old Nov 12, 2013 | 07:31 PM
djordan's Avatar
djordan
The Bulbs Are New...But I Also Realized That The Mirror Lights On Visors And The Buttons For The Map Lights Dont Work Either ...I Just Got The Suv So Idk How Long They Have Not Been Working
Old Nov 12, 2013 | 10:31 PM
alloro's Avatar
alloro
Since you just got it, you might want to start simple and see if the bulbs are good first. Back when I bought my first Expedition the interior light didn't work. I ***/u/me/d it was a circuit issue, but it ended up being all of the bulbs were no good. The PO was just an idiot that never took care of problems like that.
Old Nov 13, 2013 | 11:50 AM
Hamfisted's Avatar
Hamfisted
Ok, get a multi-meter and check for voltage at the switches. The previous owner might've had a battery drain issue and started unplugging things.
-Mike
Old Nov 13, 2013 | 04:48 PM
djordan's Avatar
djordan
ok thanks i will try that and get back to you
h0rs3p0w3r
Oct 10, 2020 12:43 AM
SATX210
Apr 23, 2019 02:05 PM
Cody93idi
Apr 10, 2013 04:06 PM
robertspangler
Mar 2, 2010 10:22 PM
bat1965
1997 - 2003 F150
Nov 26, 2004 11:49 PM
