Sponsored by: Real Truck
Hey guys need help
Old Nov 11, 2013 | 03:19 PM
Dimitri's Avatar
Dimitri
Hey guys need help
Ok guys I really need some help!!! I recently bought a 2001 f-350 xl 4 door with the 8 foot box it has the 5.4L triton v8. I was heading to a job up in northern Alberta about 10 hours away from where I live. On the drive I lost control of the truck on some black ice I was doing about 50 miles I went into the ditch but nothing crazy drove right out after. Now my truck won't do over 30 mph the engine starts to sputter and back fire I loose all my power i have no idea what's going on. At idle she revs fine but as soon as I put her into drive it's like she wants to die what can it be? Thanks
Old Nov 11, 2013 | 03:30 PM
senix's Avatar
senix
did you plug up the exhaust? Any check engine lights? How about your intake. is it clean and dry?
Old Nov 11, 2013 | 04:55 PM
donovan's Avatar
donovan
Guess
Look under the truck for damage. That is were I would start
Check Fuel lines, Fuel Filter(Replace while under there), Exhaust, Sensors.
Sounds like it starts fine but has trouble delivering fuel. No trouble codes?
That is where I would start.
Old Nov 11, 2013 | 06:19 PM
Bigpipes 35's Avatar
Bigpipes 35
My guess would be plugged up exhaust, the event might have knock the honeycomb lose in the Cat and plugged up the exhaust. Or if the Cat was hot and the snow cooled it rapidly it can crack the housing which will wreck the Cat as well..
Old Nov 11, 2013 | 09:33 PM
madsonp's Avatar
madsonp
What about the fuel cut off switch, do any of you guys think maybe that could have been activated or partially activated ? I don't know exactly how these work myself, I know they're supposed to cut the fuel off in an accident, but could they be partially activated if the accident wasn't that serious ? Might be worth a quick look.
Old Nov 11, 2013 | 10:41 PM
Dimitri's Avatar
Dimitri
Exhaust seems fine at idle in park I can rev her into the red I had a tune up done just before leaving too someone said something about speed regulator maybe but not sure
Old Nov 12, 2013 | 05:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is the transmission shifting OK?
Conanski
Jun 13, 2016 03:38 PM
ShaneS_09
Nov 28, 2007 08:38 AM
Pyrocars
Bronco II
Mar 9, 2007 08:50 AM
Quackhead94ranger
1983 - 2012 Ranger & B-Series
May 25, 2005 02:17 PM
yoda
Dec 1, 2003 08:13 PM
