6.0 no start
Old Nov 11, 2013 | 12:30 AM
BLADE35's Avatar
BLADE35
Its the guys that Get desprite and Crank for 4-5 minutes
Best thing is Keep a Charger on it if you have weaker batterys the High Press pump is Gear driven so
Iv never Put a Charger on Mine doing it but I keep that stuff in Top shape
But it does seam like it Takes a lot of crank to Fill up the System with Oil so it will build press to fire that inject
Id Definatly give a couple Blasts before we try something eles
Old Nov 11, 2013 | 09:19 AM
cummins0107's Avatar
cummins0107
Consecutive 10 - 12 seconds cranks is enough to pull enough oil up ? It does it need the continuous crank until it fills up?
Old Nov 11, 2013 | 10:06 AM
jswartz84's Avatar
jswartz84
Go 20-25 seconds on it and it should come to life. If not try again.
Rusty Axlerod's Avatar
Rusty Axlerod
I wouldn't be scared of 20-30second cranks with 5min or so between. If it hasn't started by the third try something else is wrong.
Old Nov 12, 2013 | 12:44 PM
cummins0107
UPDATE! Cranked on truck longer tried to fire up. So we tried it two more times and truck fired right up and runs good. Thanks for all the input it was extremely helpful.
Old Nov 12, 2013 | 01:49 PM
Per4mance's Avatar
Per4mance
Hmmmm......glad you got it runnin'....but ,hmmm.... maybe .....ahh forget it....I'll call ya Fummings.....LOL
Old Nov 12, 2013 | 01:56 PM
BLADE35's Avatar
BLADE35
Well what do ya Know congrates They must have several long cranks to fill back up
Feeling alittel better about Ford Now??
Hey make shure after its Hot to Give 3-4 WOT runs just to Purge any air in those lines and rails
sonofdixie
Apr 19, 2018 08:24 AM
cyber.tripp
Aug 18, 2012 04:47 PM
dbarnett42
Sep 15, 2011 05:32 AM
mwg754
Aug 29, 2011 03:45 PM
ford4x4956
Aug 12, 2009 08:30 AM
