What does the air pump do? 5.8L
Old Nov 12, 2013 | 08:40 PM
boonslick's Avatar
boonslick
Charcoal Filter
Originally Posted by 73 ford guy
Mine was disconected. Whenever truck starts it made a snap burst of air sound. I plumbed lines back on and that sound was gone. The air pump connected makes an awful growling sound. I pulled hoses off. What is its purpose, and what is that piece the 2 tubes connect to? Truck drives fine without.
I have the cannister I think you are talking about; next to battery? I was told it is a charcoal filter.
Mark
Old Nov 14, 2013 | 07:31 AM
boonslick's Avatar
boonslick
Idler Pulley
Originally Posted by dixie460
My 96 5.8L has a factory idler pulley where the air pump would be on older models. Might think about heading to the yard and seeing if you can score one of these idlers, then you can keep your stock belt.
Hello dixie460.
I have an 87 F150 5.0L E4OD 2WD XLT Lariat.
I want to install the pulley. What years will work on my engine? Will I have to modify anything?
Thank you!
Mark
Old Nov 14, 2013 | 01:24 PM
dixie460's Avatar
dixie460
Originally Posted by boonslick
Hello dixie460.
Thank you!
Mark
I wish I knew which years work but unfortunately I don't, and you have a 302 where I have a 351. I *doubt* that the mounting is any different, but I can't say that it'll bolt right up on your engine either.
Perhaps someone else can answer that, but if I were you I'd either go to the yard and get one cheap to try it out... or get one from Summit Racing, since you can call and have them verify it fits your engine before you spend $$.
Old Nov 14, 2013 | 02:26 PM
boonslick's Avatar
boonslick
Idler Pulley
Thanks dixie460.
I hope to make it to the boneyard tomorrow. They have been crushing some trucks even though there are several parts for us guys. I do not know what will be there tomorrow. There were (3) 87-88's that I was using for parts and if they are gone I am outta luck except for an Idler Pulley that I want.
Mark
Old Nov 14, 2013 | 05:19 PM
Nothing Special's Avatar
Nothing Special
Mark
That's the EVAP canister. It likely has charcoal in it. It's purpose is to keep gas fumes from escaping from the tanks to the air. The tank vent lines run through it. It's completely different from the air pump being talked about here.
Old Nov 15, 2013 | 12:12 PM
zackcj7's Avatar
zackcj7
Would this idler work?
http://www.ebay.com/itm/PFM68110-Bracket-Smog-Pump-Eliminator-Aluminum-Natural-Ford-5-0L-Kit-/321248672161?pt=Race_Car_Parts&hash=item4acbe9b9a1
Old Nov 15, 2013 | 12:53 PM
dixie460's Avatar
dixie460
That ebay listing is for Proform part # 68110.
Summit Racing shows it as applicable to your engine. And $3 cheaper too.
<a href=http://www.summitracing.com/parts/pro-68110/applications/year/1987>Compatibility check</a href>
So yes it should bolt right up on your bracket where the smog pump used to go, and use the existing belt.
Island Time
Oct 23, 2014 09:49 PM
Jaime74656
Sep 10, 2013 02:07 PM
keiser blade
Aug 27, 2009 10:43 PM
Sport45
Nov 4, 2006 06:07 PM
