TPMS questions....
Old Nov 17, 2013 | 06:37 PM
Dude Lebowski's Avatar
Dude Lebowski
Thanks for the info. According to her auction they are 315 mhz so are you saying they should be 433 mhz? What's the difference? I emailed her yesterday and she said she's sold 500 sets to owners of 2009-2014 Fords including some to F150 owners with zero complaints. A lot of the feedbacks she's received said they didn't have to train them because it happened automatically so what's the problem with my wheels? They came from the factory on a 2012 F150 XLT....
Old Nov 17, 2013 | 08:03 PM
meborder's Avatar
meborder
i guess i'm not knowledgeable to say for sure that you need one or the other, only that there are two different types.
it could be that the two types of systems use the same sensor, and the difference is in the TPMS programming. My understanding was that the two systems used two different sensors, but that may not be accurate.... there may be others that know better than I
Originally Posted by gDMJoe
If they're *new* (and not previously -used-) you will need to have them activated/initialized. Dealership|tire-shoppe should be able to perform the task.[indent]
have you tried this?
if they need to be initialized, and haven't been, then this would explain your troubles.
not sure if your new tool can do this or not.
might not hurt to verify the programing sequence in your owner's manual as well.
this site:
TPMS fits 2013 Ford F-150 OEM Tire Pressure Sensor
has a completely different programming method than your flasher sequence you eluded to earlier.
Old Nov 17, 2013 | 08:45 PM
Dude Lebowski
What do you mean by initialized? I tried the method in the owner's manual of letting the air out and gave up when it was at 25 pounds. There are several videos on YouTube under "Ford TPMS training" which show both the training tool method and also the letting air out method and they make it look real easy but it obviously hasn't been that easy for me....
Old Nov 18, 2013 | 01:29 PM
Dude Lebowski
I took it to my friendly local Ford dealer today and they couldn't train them either. They have the same training tool that I have (small grey rectangular thing that looks like a garage door remote with a red button in the middle) and they didn't have any luck. The tires had 40-44 psi and he lowered them to 38 psi because that's what it says on the door sticker for the 17s that it came with (it has 18s on it now) but that didn't make any difference. They didn't say anything about "waking up" the sensors but I did drive the truck a couple of miles before I went there (1/4 mile from my house). Any more suggestions?
Old Nov 18, 2013 | 03:28 PM
meborder's Avatar
meborder
maybe some tid-bits of info in here:
https://www.fordracingparts.com/down...htM-1180-A.pdf
i'm at the end of my knowledge, so i doubt i can be of any help.
Old Nov 18, 2013 | 05:24 PM
Dude Lebowski
On page two of your link it mentions a "customer activation tool." Is that the training tool that I already have or something else?
The eBay seller gave me a full refund of the $47.99 that I paid for them today. She said she's sold 500 sets of identical Ford TMPS sensors and never had any complaints before now. I told her if I get them trained and the problem isn't the fault of the sensors I'll send her the money back. Do you think taking the truck for a long drive could somehow activate them? The longest I've driven it with them in is 6 miles. Any other ideas?
Old Nov 18, 2013 | 06:51 PM
cartmanea's Avatar
cartmanea
Did you try doing a different wheel first? Sorry if you did already, didn't want to read the whole thread. Maybe the sensor in the front left is defective.
Old Nov 18, 2013 | 08:27 PM
Dude Lebowski
Yesterday I swapped the front and rear tires on the driver's side but it didn't make any difference....
Old Nov 19, 2013 | 09:07 AM
gDMJoe's Avatar
gDMJoe
Rather than the reset tool, you're probably going to need a bit more sophisticated to activate and/or diagnose the issue ...
FoMoCo dealership service department should be (?) equipped with one. Or ... If you've got $400-$600 to burn, you too can own one.
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old Nov 19, 2013 | 09:29 AM
gDMJoe's Avatar
gDMJoe
Dude Lebowski ... According to her auction they are 315 mhz so are you saying they should be 433 mhz? What's the difference?
315 mhz - late-2008+ stem-type.
433 mhz - pre-2009 band-type.
I emailed her yesterday and she said she's sold 500 sets to owners of 2009-2014 Fords including some to F150 owners with zero complaints. A lot of the feedbacks she's received said they didn't have to train them because it happened automatically...
I purchased a set from her last year and was one of the ones that had 0(zero) issues.
Old Nov 19, 2013 | 10:47 AM
Dude Lebowski
Could they have been installed in the wheels wrong or is there only one way to do it? I've been going to this small independent shop for years and they seem to know what they're doing. The guy who installed them has been working there for 14 years....
Old Nov 19, 2013 | 03:42 PM
Dude Lebowski
SUCCESS!!! I decided to visit two local tire stores-Big O and Ken Towery-who both have several stores in the Louisville area. I went to Big O first and three different guys tried programming them with their tool with no success. Then I drove a block to Ken Towery and the guy there put the truck in training mode a different way. I had been turning the flashers on and off three times and then it said "train left front tire" but nothing happened. He turned the key on and off several times and pushed down on the brake pedal a couple of times and put it into training mode that way. That was the correct way to do it because as he held the training tool at each valve stem the horn honked and he had the job done in less than five minutes and the best part is he did it for free. Thanks to all who offered advice and support....
Old Nov 19, 2013 | 03:45 PM
  #28
cartmanea's Avatar
cartmanea
I would have suggested the other method had I known they worked any different!
drz400dp
6.7L Power Stroke Diesel
36
Mar 31, 2019 11:08 AM
Sdowdle541
Feb 27, 2017 12:57 PM
rsjimenez
Nov 9, 2015 08:14 AM
excoelis
2009 - 2014 F150
Mar 14, 2014 11:52 AM
tbr3345
Oct 1, 2004 03:52 PM
