This is where I found the 20" lightbar for $329 and there is a $100 off code of one of my duckhunting fourms that works. "100offled" saves you $100 so its only $229.
I think we need to have a LED light shootout! The torture tests are pretty impressive.. But LEDs are solid state, they have no moving parts so they better be durable. The .22 shots were exciting, but I don't plan on using the front of my truck for target practice, at least not yet. If this were on my 6.0.... Fire away! Anyone who is in the north east and wants to cruise out on the island they can check out my lights first hand. It is really difficult to compare with lumen counts, and pictures. Actually it seems as if the only way to compare is with a side by side show down.
Thanks. I think I'm going to order that one tonight. I'm considering the 4" ones too but I'm not sure how easy they will be to replace the fogs. Might have to wait for robflag to report back.
It was a piece of cake removing my fogs to replace the fixture with LED. There are 4 bolts to remove a metal bracket that is in your way. Then you back out the aiming screw all the way, that's all that holds it in. Disconnect the wire, and coax the entire assembly, the fog light and shroud all come out together.
Did you use part of the shroud to make it look like a clean install? Got any pics?
