That right there is a BAD ICP Sensor maybe Pigtail too
Looks like you just saved $$1000.00 on a HPOP
Just about exact numbers as mine when it went bad I changed ICP sensor and was able to Clean the Pigtail with Carb Cleaner Problem Solved back on the road
I used a Long Screwdriver and Needle nose pliers to unplug it and also to plug back in
Ok. Thanks... thats good to hear... i will try and change it out tomorrow. I was able to get truck started. It took it a min to crank over but it did start..i tried to give it some gas and it wanted do die... after about a min it does die.... below is readings while truck was running and after it died.. Anyone have any suggestions...
So i unplugged the icp sensor... connector was bad i went to unplug connector and on of the wires pulled right out. All 3 wires kinda pulled out easy... truck started right up after wires came out. truck ran and then died. It started right back up.Truck would run and once you give it some gas never go above 1235 rpm. Once you let off the gas it wanted to try and die... give it some gas and it is fine... truck ran for about 5 minvor so before it died. I tried to start it and now it wont start... below are readings when i try to restart.. anyone have any idea's
Give it a lil bit and the truck started... it didnt start right away but it started.... i get one dtc and that is p2285. Below are somebother reading i pulled while it was running.
Rpm idle 628
Rpm peddle to floor 1240
Icp idle 970
Icp peddle to the floor 60 -80
Vfd idle 29.5
Vfd peddle to the floor 35.4
Mfd idle 24.5
Mfd peddle to the floor 35
Was sitting in truck waiting out the ran and the truck died. Will not start back up.. here are the new readings i get after it died and try to start it back up.
Anyone have a clue?. Hoping to pull ipr valve when it stops working and replace that along with the ipc senor when it stops raining. Assuming i can figure a way to get them out.
