hpop question?
Old Nov 13, 2013 | 02:52 PM
  #31
USMCveteran's Avatar
USMCveteran
No i havent.. how would i go about testing that
Old Nov 13, 2013 | 10:45 PM
  #32
jetjockey99's Avatar
jetjockey99
If you do find that your problem is after all, a bad HPOP the Dieselsite HPOP is the only way to go. I run one in my own truck and have replaced several in other trucks, including 2 that have had multiple OEM pumps last less than 10K miles, one of which now has 468000 miles on it, 3rd OEM pump died at 160,000 and I replaced it with the one from Dieselsite and it is still going strong, they are a much better pump than OEM
Old Nov 14, 2013 | 08:46 PM
  #33
USMCveteran
Whats the best way to test the lpop. I am replacing icp sensor, pigtail and ipr valve tomorrow... anyone have any other suggestions
Old Nov 14, 2013 | 08:48 PM
  #34
jswartz84's Avatar
jswartz84
There is a test port on the front of the oil cooler housing.
Old Nov 14, 2013 | 08:53 PM
  #35
USMCveteran
Ok. So what do i nees to do.. i just drained all the oil and gonna replace tomorrow... first gonna pull the pan and clean it out.. make sure it is clean and no other problems.
Big_wille
General Diesel Discussion
May 12, 2016 04:54 PM
Slimsadie
Jan 16, 2010 03:59 PM
BDalton
17
Apr 28, 2008 07:44 PM
