Sponsored by: Real Truck
Recon projector headlights
Old Nov 10, 2013 | 09:40 PM
automaticj5's Avatar
automaticj5
Just saw the look on the video. Jk on that...
So how do I know it's 6000k? And any ideas on how to find one with wire resistors built in?
Old Nov 10, 2013 | 09:43 PM
02TB250's Avatar
02TB250
You may not be able to find them. Not all cars need them and some people like the hype flash.
Your more then likely going to just need to find a auction with the resistors included so you don't have to buy them separately
Old Nov 10, 2013 | 09:45 PM
2ndStroke's Avatar
2ndStroke
Yup 3157 is the bulb you need, the resistors won't be build in, you with have to wire them in. Should say somewhere the k of the bulb. The seller I bought from included the resistors.
I think there is a anti hyper flash fuse you can get as well...
Old Nov 10, 2013 | 10:10 PM
automaticj5
Originally Posted by 2ndStroke
Yup 3157 is the bulb you need, the resistors won't be build in, you with have to wire them in. Should say somewhere the k of the bulb. The seller I bought from included the resistors. I think there is a anti hyper flash fuse you can get as well...
Where did you mount the resistors?
Old Nov 10, 2013 | 10:17 PM
2ndStroke's Avatar
2ndStroke
Zip tied them to the main wire bundle.
Old Nov 10, 2013 | 10:20 PM
automaticj5
[QUOTE="2ndStroke;13727802"]Zip tied them to the main wire bundle.[/QUOTE
Perfect. Didn't know if it would melt it..
Old Nov 10, 2013 | 10:29 PM
2ndStroke's Avatar
2ndStroke
[QUOTE=automaticj5;13727814]
Ah, your right. They do make heat. I know I ziptied them, but I can't remember to what exactly , sorry it's been close to a year and half since I put them in....
Old Nov 11, 2013 | 02:22 PM
weyland426's Avatar
weyland426
I'm seeing a ton for bulb 3157 replacement but I don't see any with wire resistors... I also don't see where it says 6000k. Only "white color"
Question - at night both the white color and your headlight is on at the same time?
How's that look?
check autolumination.com...very thorough website and almost instantaneous customer service email reply if you have questions.
Old Nov 11, 2013 | 02:35 PM
automaticj5
Awesome thanks!
Old Nov 11, 2013 | 03:13 PM
Dogmann's Avatar
Dogmann
Sick! Absolutely awesome
mooch91
Mar 29, 2019 11:41 AM
Bat4x4
Aug 23, 2016 08:06 PM
three.on.the.tree
21
Apr 21, 2016 06:36 PM
Bugzilla46310
Feb 7, 2016 06:30 PM
SYKOLINCOLN
1997 - 2003 F150
39
Jan 4, 2008 08:00 PM
