Sponsored by: Real Truck
Recon projector headlights
Old Nov 8, 2013 | 06:43 PM
automaticj5's Avatar
automaticj5
Hey all!
Just wondering whose done the swap to the projector headlights. I see two options for the 11+ trucks... LED or CCFL halos...
The one thing I hate about our headlights is the gaudy amber turn signal light above our headlights... Do either of these get rid of that?
What's your opinions on either?
Thanks!
Old Nov 8, 2013 | 07:02 PM
2ndStroke's Avatar
2ndStroke
I don't think recon gets rid of the yellow, the stock turning bulb is reused. A few guys have the recons in the 6.7 section.
I didn't like the yellow either.
Old Nov 10, 2013 | 09:16 AM
2012 SD Snowbuster's Avatar
2012 SD Snowbuster
2nd Stroke that looks killer! So what did you do for turn signals?? Please give up the info on that sick looking headlight setup??
Old Nov 10, 2013 | 11:29 AM
2ndStroke's Avatar
2ndStroke
They are led "switchbacks". They stay 6,000 k like they are in the pic for your driving lights and they switch to amber, and flash when you use your turning signals
Old Nov 10, 2013 | 12:43 PM
Iggy2867's Avatar
Iggy2867
Oh, you need to post a video of that
Old Nov 10, 2013 | 01:04 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
that is neat, but check your local DOT for legality
I want the 08+ front end so bad on my X!
Old Nov 10, 2013 | 01:06 PM
2ndStroke's Avatar
2ndStroke
Just like these....
Old Nov 10, 2013 | 02:14 PM
weyland426's Avatar
weyland426
I just installed 92ct tower LED switchbacks and load equilizers. The "driving" lights work great as DRL's and I intend to hotwire them to an ignition circuit so they are always on. I would like like my heads and fogs to match...what did you use for these replacements, 2ndStroke?
Old Nov 10, 2013 | 02:35 PM
2ndStroke's Avatar
2ndStroke
The heads and fogs hid kits? I used retro-solutions, but I will never recommend them to anyone, sorry I'm looking for a new company as well.
Old Nov 10, 2013 | 02:45 PM
02TB250's Avatar
02TB250
I used the retrofit source for my hid/projector upgrade. Great customer service
Old Nov 10, 2013 | 08:37 PM
automaticj5
So what's needed to change this out?
I've already done the HID conversion on my heads and fogs...
Is this another conversion on the turn signals or just a bulb to LED plug and play replacement?
Where did you buy from?
That's awesome. Thanks
Old Nov 10, 2013 | 09:10 PM
2ndStroke's Avatar
2ndStroke
Plug and play off eBay, plus something to prevent hyper flash, ie. wire in resistors.
Old Nov 10, 2013 | 09:14 PM
automaticj5
Awesome. What do I need to search for on eBay? "Led switchbacks" and separately "wire resistors"? Are there different plug sizes or types or are they universal?
And then just be sure to get 6000k so it matches my lights and fogs?
Thanks!
Old Nov 10, 2013 | 09:21 PM
2ndStroke's Avatar
2ndStroke
Ya my set came with the resistors, but I think there are other ways to prevent the hyperflash. I just typed f250 switchbacks I think
Old Nov 10, 2013 | 09:38 PM
automaticj5
I'm seeing a ton for bulb 3157 replacement but I don't see any with wire resistors... I also don't see where it says 6000k. Only "white color"
Question - at night both the white color and your headlight is on at the same time?
How's that look?
