Turn signals?
Old Nov 8, 2013 | 03:22 PM
CC_Brunner's Avatar
CC_Brunner
Turn signals?
Turn signals work perfect when I don't have the headlights on, but as soon as I turn the headlights on the running lights come on and the front turn signals don't. The rear ones work either way. I've replaced the bad fuse and bulbs, and I couldn't find any split wires or a ground short so I don't know what to do..
Old Nov 8, 2013 | 04:12 PM
Roger Carter's Avatar
Roger Carter
Sounds like the headlights and/or the turn signals are using the other as a ground path. Check for good grounds at the headlights and the turn signals. Make sure the groung connections are made to clean, raw metal. Paint and rust aren't good conductors.
Also, check for corroded sockets in the turn signals.
Roger Carter
Old Nov 9, 2013 | 07:59 AM
fmc400's Avatar
fmc400
MSEE
This is a textbook case of ground shift. 99% of the time; it's due to bad sockets. Replace both front sockets.
japrine
Mar 23, 2015 06:28 PM
rmalottwtes30
Mar 13, 2008 12:37 AM
trike1946
Electrical Systems/Wiring
17
Mar 27, 2006 11:53 PM
tatwood
Jun 5, 2004 12:52 AM
Billavista
Apr 25, 2003 07:31 PM
