tuen signal problem
Old Mar 12, 2008 | 11:33 PM
rmalottwtes30's Avatar
rmalottwtes30
tuen signal problem
When my headlights are off my drivers side turn signal works, but when I turn on the headlights or running lights the driver side turn signal wont come on. Anyone know why or what I should check for?
Old Mar 13, 2008 | 12:37 AM
Franklin2's Avatar
Franklin2
Pull the turn/marker bulb out of the front driver's side, take the bulb out of the socket and clean the brass part of the bulb and the little tang that contacts the brass part in the socket, and then try it. If that doesn't fix it, then replace the socket. I had two different sockets that went bad. They have a slip on connection up in the middle that corrodes.
