Up Pipe Mod
Old Nov 7, 2013 | 07:22 PM
billbot's Avatar
billbot
Up Pipe Mod
For those that have done the up pipe mod by removing the scoop and welding in a plug, how has this mod held up over time?
Old Nov 7, 2013 | 09:38 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
I've had my stealth delete with scoop removed and plugged for around 15000 miles with no issues or cell, mines a late 05.
Old Nov 7, 2013 | 09:59 PM
billbot's Avatar
billbot
Glad to hear its working, thanks
Old Nov 7, 2013 | 10:00 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Holds up just fine. I have stealth delete with a welded cooler.
Josh
Old Nov 7, 2013 | 10:09 PM
xaviar's Avatar
xaviar
When I was doing my HG's I came across a up-pipe without the scoop on Ebay. I bought it and installed it on my truck. I've had no issues with it since it's been on my truck the last 9K miles.
This brings on a question. Did Ford make some of those up pipes (early run 6.0's) that didn't have the scoop in them? When I removed my up-pipe. It had the scoop and for the life of me I couldn't remove the scoop. The one I bought off Ebay didn't have any cut marks of any kind on it. Makes me believe ford made some without the scoop then added it later. My truck is an 06.
Old Nov 7, 2013 | 10:13 PM
billbot's Avatar
billbot
Sounds good, just thinking it would be nice to have an option to choose stock or deleted by swapping up pipes. I see a lot on of used up pipes on eBay for cheap. Along the same lines as a cat delete pipe I guess.
Old Nov 7, 2013 | 10:22 PM
billbot's Avatar
billbot
Not sure about the later ones. I thought the early style for round egr coolers did not have the scoop. Glad it has worked out for you.
Old Nov 7, 2013 | 10:27 PM
Bullitt390's Avatar
Bullitt390
The early style rounded coolers have an up-pipe with no scoop.
It also seems the 05+ F450 and F550 with 6.0 engines also do not have the scoop even though the F250/F350 did.
Josh
Old Nov 8, 2013 | 03:26 AM
HeavyAssault's Avatar
HeavyAssault
When I was using the "sneaky pipe" it worked great. Drove for PLENTY of miles before going to the full delete and a ported manifold. Never an issue. I would suggest for those who "need" the sneaky option to replace the expansion bellows with some HD bellows.
Old Nov 8, 2013 | 11:39 AM
billbot's Avatar
billbot
Sounds good, looking into the HD bellows. I didn't realize it was a common failure until now, and with the extra flow I can see why you'd recommend that.
Old Nov 8, 2013 | 12:32 PM
Bullitt390's Avatar
Bullitt390
Like this...
Josh
Old Nov 8, 2013 | 01:17 PM
xaviar's Avatar
xaviar
Good job josh. I kept my old y pipe and will be replacing the bellows in the future.
Old Nov 8, 2013 | 02:22 PM
billbot's Avatar
billbot
Nice! How did you source the bellows?
Old Nov 8, 2013 | 02:35 PM
Bullitt390's Avatar
Bullitt390
Those are made by Vibrant and are 3 layered.
I'll create a write up on repairing a y pipe later today.
Josh
Corner Gas
Feb 7, 2011 07:15 AM
PeterAL
Mar 2, 2010 08:04 PM
Robert6401
Jul 11, 2009 03:49 PM
truckeemtnfords
Jan 27, 2009 02:41 PM
Bigfwt04
17
Jan 6, 2009 03:50 PM
