cps
Old Nov 7, 2013 | 05:46 AM
stonemason's Avatar
stonemason
cps
ok I went to ford and ordered two cps and they will not fire my 95 . here are the part # f4tz-12k073 black other one f7tz -12k073-b . I really don't wont to run auto zone cps but they are the only one that works am I missing some thing guys thanks
Old Nov 7, 2013 | 06:27 AM
ReBilld's Avatar
ReBilld
That's strange. Did you put one of the Ford ones in and it not work, then put the Autozone one back in and it did, or did you take a working Autozone one out and put in a Ford one and that's where you're at now?
Old Nov 7, 2013 | 03:32 PM
stonemason's Avatar
stonemason
ok I got a new cps from ford ( black) when I had no tack movement . then went to auto zone got one an that worked So I thought I just got a bad one from ford dealer and went to another dealer brought a gray one and a black one no go. Not sure what is going on but as of now auto zone cps is working and at 34.00 per x 3 = 102 .00 in cps"s
Old Nov 7, 2013 | 07:09 PM
ReBilld's Avatar
ReBilld
Maybe one day when you have a few minutes, swap one of the Ford ones back in and fiddle with the wiring all the way up to the harness, just to see if you have a wiring problem. Or maybe even better yet, fiddle with the wiring while the Autozone one is in there and see if it quits working.
Highridge
May 15, 2011 05:14 PM
Bigcat350
21
Jan 7, 2010 04:49 PM
7.3mule
Feb 18, 2009 01:47 PM
jetdoc
Feb 20, 2008 07:05 AM
Mindstream
34
Jan 26, 2007 07:32 PM
