Sponsored by: Real Truck
Help Deciphering Axle Code
Old Nov 6, 2013 | 04:39 AM
79F150EFI's Avatar
79F150EFI
2001 F250 4x4, Ext cab, utility bed (possible cab and chassis?),5.4l triton. It looks like the door tag gives an axle code of 47. However, every axle code chart I have seen (including the one posted here in the tech articles), does not list a 47 axle code. I cut and paste the chart posted here below for reference.
I am interested in buying this truck, but haven't physically looked at it yet due to it being quite a few hours away. I want to make sure the gear ratio will work for what I have in mind. Since it has the 5.4l, I am concerned it may have very steep gearing.
Here is a pic of the door tag:
Walmart Digital Photo Center: Share:Photo View
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
F3 — 4.30 limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
Old Nov 6, 2013 | 04:47 AM
SC_Hoaty's Avatar
SC_Hoaty
Looking at this post
Ford Door Sticker Decoder .: Articles
It appears the 47 is the Region Code. Looks like Axle code is blank. Curious.
Old Nov 6, 2013 | 04:49 AM
redford's Avatar
redford
FTE Leadership Emeritus
Those codes are for the axle tag, not the door sticker.
You have a 4.10 LS
I ran your VIN at FordEtis home page and got this:
Primary Features
Build Date: 10.08.2000
Vehicle Line: F250/350/450/550 Super Duty
Body Style: Super Single Cab
Version: 250 Series
Engine: 5.4L Modular SOHC V8
Transmission: E4OD(4R100)
Drive: LHD 4WD (PTD)
Axle Ratio: 4.10
Emission: With 49 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Paint: Dark Toreador Red
Old Nov 6, 2013 | 04:50 AM
redford's Avatar
redford
Also:
Minor Features
Medium Parchment
Blocker Beam-Underbody Front End
With Tailgate Lock
With 8' Styleside Box-Steel
With Load Box Edge Protectors
158"/4013MM Wheelbase
Lariat
(-) Version Packages
Less Special Purpose Vehicle
Less Fleet Related Items
Kentucky Truck Plant Build
U.S. Sales
Less Special Equipment Package
8800 LB. GVW
Less Appearance Group
Less Cold Weather Group
With Off Road Appearance Pack
With Power Equipment Group
Less Ambient Temp/Speed Pack
With On-Board Diagnostic System
Kentucky Truck Plant Build Only
With English Language Label
Owner Hand Book Pack
With 2 Ton Mechanical Jack
Less Warning Display
Less Fire Extinguisher
Less Tool Kit
With Power Front Windows
With Hinged Side Windows
With Privacy Glass
With Sliding Rear Window
Standard Ovrhed Console & With Rail
With Full Floor Console
Fixed Foot Pedals
With Carpet Floor Covering
Less I/P Insert
Sunvisor - Dual Drv Illuminated
Sunvisor - Dual-Pass Illuminated
With Level 4 Door Trim Panel
With Sound Insulation Pack Level 1
Less Exterior Sun Visor
With Bright Front Grille
With Lower Body Moulding
Less Rear Window Protector
With Side Auxiliary Step W/O Lights
With Dipping Rear View Mirror
Dual Sail Telesc TT Power Mirror
With Drivers Heated Seat
With Heated Passenger Seat
With Seat Belt Warning Light
With 2nd Row Bench Seat - 3 Passngr
With Driver 6 Way Pwr.Seat Adjuster
Trailer Tow Prep Pack
With Trailer Towing Attachments
With Front Towing Hook
Exterior Door Handle - Black
With Central Locking System
With Door Entry Remote Control Unit
Less Body Tu-Tone Paint
Less Bodyside Accent Stripe
Front Bumper - Steel Chromed
Rear Bumper - Steel Step - Chromed
With Front Licence Plate Bracket
With Inertia Front Seat Belt
With Driver Air Bag
With Passenger Air Bag
Adjustable'D'Ring-Drivers Seat Belt
With Passenger Air Bag Deactivation
With Frame Mounted Tyre Carrier
With Steel Spare Wheel
With Single Rear Wheels
7.0 X 16" 6 Window Aluminium Wheel
LT265/75R-16E Owl A-S Tyre
With Conventional Spare Tyre
Less Wheel Covers
With Bright Wheel Hub Cover
Less Immersion Heater
Less Attitude/Ride Height Pack
With Standard Duty Front Suspension
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Stabilizer Bar
4.10
Rear Axle Limited Slip Differential
Ford Axle Type
With Mono Beam Front Axle
With Catalyst
With 4 Wheel Disc-Brake
4 Wheel Anti-Lock Braking System
With Standard Transmissn Oil Cooler
Less Transmission Power Take Off
Electric Trans Case And Auto Hubs
With Skid Plates
With Mid-Ship Fuel Tank
Less Auxiliary Fuel Tank
With Non Locking Fuel Cap
For Unleaded Fuel
Less Gaseous Prep Pack
Less Diesel Fuel Content
With Steering Damper
With Tilt Steering Wheel
Leather Steering Wheel
With Speed Control
With MPH/KMH Speedometer
Less Reverse Proximity Sensor
Less Engine Immobiliser
Heavy Duty Battery
Heavy Duty Alternator
Elect Prem Stro/Cass/Disc/Clock
Less Radio Pre-Equipment Pack
With NAAO Radio Frequency
Less Daytime Running Lamps
With Aero Headlamps
With Front Fog Lamps
Less Roof Marker/Clearance Light
Engine Compartment Light
With Dual Beam Dome Map Light
With Glove Box Illumination
With Load Compartment Lamp
Tail lamps - Level 1
With High Mounted Stop Lamp
Dark Toreador Red
Left Front F81A-5310-ADD (4400 LB.)
Right Front F81A-5310-ADD (4400 LB)
Less B&A Control Codes Issue 030388
Less LPO 50S Emiss Calib Label
(+)"USA"
(-)"CDN"
(-)"AUS"
(-)"RA"
(-)"GU"
(-)"BRN"
(-)"VN"
Old Nov 6, 2013 | 05:18 AM
79F150EFI's Avatar
79F150EFI
Thanks a bunch! Never owned a superduty before, but my older trucks all had the axle code listed on the door.
Old Nov 6, 2013 | 05:30 AM
redford's Avatar
redford
Yours should have a door code. It is odd that it does not, as SC_Hoaty pointed out.
Old Nov 6, 2013 | 06:29 AM
projectSHO89's Avatar
projectSHO89
Hmm. Maybe it doesn't have an axle!
LoriMeyer
Jul 28, 2018 10:41 AM
Randallman
May 22, 2011 10:03 PM
NJBronco94
Sep 20, 2010 12:09 PM
thedieselkid
Sep 5, 2010 11:11 PM
oggjay
Oct 30, 2005 12:10 AM
