Sponsored by: Real Truck
Tech Folder
Old May 21, 2011 | 03:19 AM
Randallman's Avatar
Randallman
Tech Folder
I just noticed there is two different axle gear ratio charts in the tech folder and just wanted to get clarification. The bottom chart I listed here is on the same post talking about the vehicle certification label which I'm assuming is one of the labels in the driver's door right? What is this top chart for? Is it the code on the axle tag underneath the truck?
This one is third post from the bottom:
AXLE CODES:
37- 3.73
3L- 3.73 LS
41- 4.10
4N- 4.10 LS
43- 4.30
4L- 4.30 LS
48- 4.88
8L- 4.88 LS
53- 5.38
5L- 5.38 LS
Third post from the top:
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
F3 — 4.30 limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
Old May 22, 2011 | 05:08 PM
bpounds's Avatar
bpounds
The shorter chart is for trucks '05 and up. The longer chart is for '04 and older.
Old May 22, 2011 | 09:57 PM
Randallman's Avatar
Randallman
Ah ok that makes sense. Although it still doesnt help me lol. Either my sticker doesnt have an axle code listed. I was looking for my ratio and tag on the rear end said (bolt)L30 10 5 which I thought meant 4.30 Limited Slip and looking at the door codes I couldnt verify but thankfully someone else on here did verify it for me. Wonder why Ford didnt put D3 under the axle code instead of leaving it blank.
Old May 22, 2011 | 10:03 PM
Mr-Pipeline's Avatar
Mr-Pipeline
My door sticker under axle code is also blank. Not sure why some have it and other don't?
blloyd29
Mar 28, 2016 07:11 PM
Sparky04SD
Mar 16, 2011 12:14 AM
V8EXPLR
Aug 1, 2008 02:43 PM
mia
Apr 10, 2007 08:52 AM
Vaccuum
Sep 28, 2001 05:28 PM
