Sponsored by: Real Truck
axle code unc
Old Feb 17, 2010 | 05:03 PM
thedieselkid's Avatar
thedieselkid
axle code unc
2000 cab and chassis f350 2wd. non dually. can't find it anywhere other numbers above where it says axle is rc44 below is UNC to left is r7 to right is tr6.
Does anyone know what rear and gear are in it???
Old Feb 17, 2010 | 07:12 PM
_Rick_'s Avatar
_Rick_
Kid,
What "axle" code is on the sticker on the drivers side door pillar?
Find the code on the sticker then read the list below to find the gear info.
Rick...
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
F3 — 4.30 limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
Old Feb 17, 2010 | 07:46 PM
thedieselkid
hey rick. thanks for a response. only thing i see is UNC.
here it is
http://i22.photobucket.com/albums/b3...8/IMG_0285.jpg
Old Feb 17, 2010 | 08:07 PM
_Rick_'s Avatar
_Rick_
That's odd. The axle code is missing on your sticker. It should be JUST below AXLE.
The UNC is related to something else. Mine has UTC.
Does there happen to be metal tab attached the dif?
Rick...
here it is
Old Feb 17, 2010 | 08:23 PM
thedieselkid
didnt get it home yet the snow is too high at my house. bought it for the cab. can't believe it doesn't have axle code. is there a way to get it off vin?
http://i22.photobucket.com/albums/b3...8/IMG_0279.jpg
http://i22.photobucket.com/albums/b3...8/IMG_0280.jpg
Old Feb 17, 2010 | 08:27 PM
thedieselkid
would a pick up bed fit on it? its a cab chassis
Old Feb 17, 2010 | 08:28 PM
_Rick_'s Avatar
_Rick_
Another odd point.
Your vin comes up as:
F-350, SuperCab (Chassis Cab), 4x2, single rear wheels.
but:
All the axle codes only show dual rear wheels?
I wonder if there is a standard gear ratio for cab & chassis with SRW?
I hope some one can chime in here to clear this up. Maybe there's something terribly obvious we're missing with this.
Rick...
Old Feb 17, 2010 | 08:32 PM
_Rick_'s Avatar
_Rick_
I already confirmed your vin as:
On your vin: Positions 5 through 7 indicate vehicle line, series and body type
X34= F-350, SuperCab (Chassis Cab), 4x2, single rear wheels
Rick...
Old Feb 17, 2010 | 08:35 PM
thedieselkid
thanks Rick i just did everything you did. maybe that list of axle codes is incomplete because it doesn't say f350 chassis cab single rear wheels.It list's f350 single wheel but it doesn't say chassis cab like with the others.
Old Feb 17, 2010 | 08:38 PM
_Rick_'s Avatar
_Rick_
Yup, only a month ago a friend installed a salvaged '03 bed on his '01 stock ordered cab and chassis. He said it went very smooth but I have no idea if there was any brackets or additional parts needed. He said he had access to both vehicles so what ever he needed was on the donor truck.
Rick...
Old Feb 17, 2010 | 08:52 PM
_Rick_'s Avatar
_Rick_
Snow too high,,, brrrrrr,,, it's cold.
waaahhhhh!
Go look for the tag.
Hopefully it's still there for you.
You got me more than curious as to why there is no axle code on the door post sticker and you're gonna shut me down? Sheesh...
Rick...
Old Feb 17, 2010 | 08:56 PM
thedieselkid
lol sorry man. the truck is 80 miles from my house! I should've checked when i paid the dude. I'm not whining. I'm having it towed to my house but i have a 300 ft driveway with 3 feet of snow. I wish my driveway looked like the one in the pic. No place to put it right now. if it was here i would have been under it already!!! i took a pic of the tag so i could look up the codes i like these song and dance deals i get. especially when they have good stuff on them.
Old Feb 17, 2010 | 09:10 PM
_Rick_'s Avatar
_Rick_
Fair enough.
I'm still hoping someone will stop by here with some "axle" insight. We might be missing something obvious or there is simply a standard gear ratio for your particular chassis.
Rick...
Old Feb 18, 2010 | 09:17 PM
thedieselkid
hey there my canuka friend. well i was at work and a f550 came to make a delivery. Guess what? No axle code on there either. I don't think any cab chassis have axle codes.
Old Feb 18, 2010 | 09:31 PM
_Rick_'s Avatar
_Rick_
That's another new "Ford" thing I've learned today. (no axle codes on Cab'N'Chassis pillar stickers)
Seems odd though? There must be some kind of reference on the C&C vehicles that state what axles are in them. I hope the tab on the rear differentials are at least installed on them?
Rick...
