Modular V10 (6.8l)
Vacuum Leak? 2001 Excursion
Old Nov 5, 2013 | 04:36 PM
xplodn's Avatar
xplodn
I have searched both under the hood and here... no answers yet.
2001 6.8, California model. I have what sounds like a significant vacuum leak. I have felt all around by the Throttle body and ICV and cannot feel, see or find anything cracked or loose. I also sprayed a bunch of carb cleaner everywhere I suspected and cannot find it. It there a pronounced vacuum sound naturally?
I did check all the elbows I can find with no cracks and the PCV while loose in the grommet and barely sucking vacuum, messing with it does not appear to change the noise.
Old Dec 14, 2013 | 05:39 PM
Elmo154's Avatar
Elmo154
PCV valve seating
If you have the water heated PCV valve make sure the water loop is installed correctly so that the PCV valve can seat all the way in the crankcase.
cgunning17
13
Sep 7, 2018 08:05 AM
dharte
Nov 1, 2014 06:28 PM
fordguy62
Feb 19, 2014 08:20 PM
mr_ranger-79
25
Feb 12, 2011 09:06 PM
freewheelin
Aug 21, 2004 02:40 AM
