leak detection under vacuum
Old Aug 20, 2004 | 10:01 PM
freewheelin's Avatar
freewheelin
I am about to pull a vacuum and then recharge on my 1979 bronco. It currently does not have enough refrigerant to cool at all and I think it might have been open for a short time. Question is when I pull the vacuum, is there a way that I can pinpoint leaks without having to charge it? Would the soapy water method work under a vacuum or any other method?
Old Aug 21, 2004 | 02:40 AM
Pikachu's Avatar
Pikachu
Don't use soapy water under a vacuum.You don't want to be sucking water into the system.
If you pull a vacuum to more than 29 inches, close the valve to the pump and shut it off, it should hold for an hour. If you are still concerned about a leak, you can pressurize the system with dry nitrogen then use the soapy water.
