alternate placement intercoolers?
so, i'm starting the daydreaming process now of how the whole medium/high-performance motor is going to come together and got to thinking about intercooler placement.
I know the standard practice is to jam an SD intercooler in front of the AC condenser, and behind the grill. while obviously not impossible, it seems that requires a good bit of radiator support cutting and quite a bit of tube fitting and snaking down from the turbo and back to the plenums. plus, i'm always a road-less-travelled kind of guy...
with my plans of doing e-fuel, electric fans, and relocating my batteries back under the frame somewhere, I was thinking, maybe i'd try to get creative and use this freed-up space to locate an intercooler (or two) somewhere else.
some quick internet-poking-around led me to these (Mishimoto Universal Intercooler Z-Line, Black, by Mishimoto) which are reasonably priced and look like maybe two of them (or some of the other small ones) could be squeezed where the batteries used to be. of course some interesting cold-air-directing will be needed, but just wondering if anyone has done this, or knows of anyone having done anything like this.
I guess even the combined size of two of these would be less than a stock SD cooler, but i'd bet you'd get something like 75-90% of the benefit of the larger one - and maybe a few less install headaches - or at least different headaches :-)
just some thoughts to throw out there on a Monday morning :-)
That link with those intercoolers doesn't look like something that is going to even be worth putting on. I don't think they would help much at all. I think you'd be more along the lines of 20% of a SD intercooler. I didn't see what size the inlet/outlet are, but sure don't look like 3 inch either.
You'll like the batteries out of there, I know I do. I love being able to just shut my power switch off instead of having to unhook them when needed too. So, if you do that, install one. Good antitheft device if you need it too.
Ah, heck, just put another turbo in where one of the batteries was.
does anyone know some typical intercooler inlet/outlet temps on our trucks? with those numbers and the dimensions of the intercooler, it'd be possible to calculate the relative cooling able to be achieved by a smaller unit.
and before anyone says it, yes, I am a big dork, but since i'm also cheap, broke, and lazy it comes in handy sometimes :-)
a good point! a higher end turbo can be expected to make ~30 psi or more, right?
I can't imagine that an all-aluminum, welded intercooler could only handle 22psi, though. I bet the lawyers made them state that number :-)
anyway - thanks for the feedback guys. this won't go anywhere fast, but its nice to have other guys to bounce my crazy ideas off of!
