need help ASAP
Old Nov 8, 2013 | 10:06 AM
  #46
suthernboi4lyfe's Avatar
suthernboi4lyfe
Originally Posted by Money-Pit
Did it go up and down at all, or was it stuck on 2 psi always?
It just stayed at 2. The pyrometer gauge moves so I can tell it works, but not sure what's up with the turbo gage
Old Nov 8, 2013 | 10:17 AM
  #47
Money-Pit's Avatar
Money-Pit
Does it go to 0 when you turn the truck off, or stuck at 2? As you accelerate or climb a hill it should rise some....then when you let off the throttle to idle for a stop, it should drop to close to 0. If you floor the throttle, it should go way up within 5 seconds while you are driving down the road. (I think 25-28 psi? ....I'm not a 7.3 expert)
Old Nov 8, 2013 | 01:02 PM
  #48
Stewart_H's Avatar
Stewart_H
Wait, what? So it doesn't react the way I described in post #42 above?
Stewart
Old Nov 8, 2013 | 01:17 PM
  #49
suthernboi4lyfe
It does not ever leave 2#. The bottom of the gauge is 2#. I can hear the turbo but dont see any indication of pressure.
Old Nov 8, 2013 | 02:00 PM
  #50
Money-Pit's Avatar
Money-Pit
Either the plastic tubing has disconnected somewhere, or the gauge is broke. I'm betting the line is disconnected someplace. Trace it from your gauge to the motor. It probably popped out of the T compression fitting.
Old Nov 9, 2013 | 10:41 AM
  #51
suthernboi4lyfe
So I had ford change oil and do a coolant flush. They inspected it also and said I need a new power steering pump and front axle seals as well as transmission coolant hose and lines. Something that can be done by the average guy?
Old Nov 9, 2013 | 11:22 AM
  #52
Pitcrw6's Avatar
Pitcrw6
Yes the average guy can do all that but why does all that have to be done? Did you ask him? Always ask why and have them show you its bad then bring it home and get on here to learn how to do it and save yourself big $$$$$.
Old Nov 9, 2013 | 11:31 AM
  #53
Kdr358's Avatar
Kdr358
My Previous EX had 294,000 miles on it, Original everything minus the injectors. You got a very good deal, In the rust belt clean trucks are hard to come by! Your Ex would probably bring 14-15k if it was here.
Old Nov 9, 2013 | 09:13 PM
  #54
suthernboi4lyfe
Front axle,v power steering pump, and a fitting on the transmission cooling line are leaking
Splatts
Mar 9, 2013 11:05 PM
EYDI819
Oct 19, 2012 05:52 AM
MPA11
Mar 1, 2012 11:21 AM
messeswithtrux
May 26, 2011 02:22 PM
BADCAR
Sep 25, 2006 08:11 PM
