Window won't work after Power Lock Fix
Old Nov 3, 2013 | 03:14 PM
Crunk's Avatar
Crunk
So after a lot of work, I got the door actuator fixed. Instantly after, the window was sluggish to go down but it went all the way down, then it was sluggish to go up. Striked me as odd. Maybe I got a wire in the way? Happened twice more and then it wouldn't go down past an inch (from the top) and still will barely move. Any ideas on what could have happened or how I fix this? It is the driver's window and I live in a gated apartment complex
I should probably note that I had to unscrew that beam on the very left of the door (close to the actual door lock) and it wouldn't go back after 20 minutes of haggling with it so I took a small hammer and hit the bottom part of it so it would be aligned with the hole for the bolt. If this caused the problem, how much of a nightmare is it to fix it...?
Old Nov 3, 2013 | 04:34 PM
Crunk's Avatar
Crunk
Ugh this is frustrating.
Old Nov 3, 2013 | 05:18 PM
Apocalypse's Avatar
Apocalypse
The only thing I can think is a pinched or badly kinked wire somewhere in the drivers side. Recheck the connectors and make sure they're clicked in all the way? How are the rear windows?
Old Nov 3, 2013 | 05:36 PM
Crunk's Avatar
Crunk
I did. I'll add a video of the window in a minute
JMM-MD
Nov 22, 2011 08:33 AM
krehjc
Paint & Bodywork
Jun 14, 2011 05:42 PM
RMbros
1997 - 2003 F150
16
Jul 3, 2007 11:42 AM
roustabout04
Aug 16, 2006 06:09 AM
shift1313
Jul 9, 2005 10:53 PM
