1978 - 1996 Big Bronco
Ignition system
Old Nov 3, 2013 | 07:32 AM
Pickle boy's Avatar
Pickle boy
Ignition system
I recently purchased a 1994 broco 5.8 liter . I am having a severe engine miss. Set ignition timing checked for intake leaks checked fuel pressure regulator and still have bad misfire. My next step is going to replace cap rotor wires and plugs, my question to you guys is two things 1 should I only use motor craft parts or can I use MSD ignition parts and 2 is there anything else I should check? I am new to the ford world and would love some help! Thanks
Old Nov 9, 2013 | 09:18 AM
Pickle boy's Avatar
Pickle boy
Well after putting a new dist cap rotor and spark plugs the has decreased alot but there is stil a small miss. I ran some carbon cleaner through the intake but no better . What else?
Old Nov 9, 2013 | 11:43 AM
Conanski's Avatar
Conanski
Run the engine in the dark with all vehicle lights off(pull fuse to disable DRL if you have them) and look for arcing from the plugs or wires.
Old Nov 11, 2013 | 03:50 PM
Southern Bronco's Avatar
Southern Bronco
I had the same problem with my 94. Found it was a bad distributor.
Old Nov 23, 2013 | 11:29 AM
Pickle boy's Avatar
Pickle boy
Bad distributor huh ok thanks
bubbareitz
Jul 15, 2015 07:57 PM
rwdfan
Jul 4, 2011 04:29 AM
dgassett
Mar 27, 2007 04:48 PM
Tom
General Automotive Discussion
Oct 25, 2005 08:33 AM
Will_01_GT
Mar 23, 2004 01:28 PM
