New ignition question.
Old Mar 25, 2007 | 05:04 PM
dgassett's Avatar
dgassett
I had a question about ignition earlier, it was answered well. As I was wandering through the internet and it's infinite wisdom, it suddenly dawned on me. I did not realize I had a point style distributor. I had set the gap on my autolite plugs to .044 because I was told so. I noticed that there are threads regarding HEI upgrades and the new gap size of the plugs. Does that mean that I may have mine gapped way to far? Should they be gapped a little smaller. If so that may explain the running rich issue right. While I am here. Does that mean I should get a different Cap and Rotor? I have no funds to go buy a new HEI or pertronix upgrade. I will have to deal with the points for now.
Old Mar 25, 2007 | 05:07 PM
dgassett's Avatar
dgassett
Oh yeah it is a 351w. I was told it came out of a 79 E100. But the guy7s here say that comes with the non point system. But, after knowing what I am looking at, I do have a point system inside my 72 f100.
Old Mar 25, 2007 | 05:18 PM
ken75ranger's Avatar
ken75ranger
I think your gap is too wide. IIRC the gap should be .035 for a points distributor.
The cap and rotor should be ok.
Old Mar 25, 2007 | 09:20 PM
dgassett's Avatar
dgassett
thanks I will re gap the plugs
Old Mar 26, 2007 | 07:01 PM
mhg's Avatar
mhg
ken75ranger is correct
this should not change the rich problem though
Old Mar 26, 2007 | 07:32 PM
dgassett's Avatar
dgassett
would it change my timing. In turn change how the fuel is burnt. Thus producing that rich running smell of fuel or exhaust. I don't know, that is why I ask.
Old Mar 26, 2007 | 08:26 PM
mhg's Avatar
mhg
the plug gap wont change the timing
the point gap will but only a degree or 2
if it is that noticable then it almost must be
the carb
its evident that the po kept the original dist when changing
the engine
when you are ready to upgrade the ignition look
into using a ds2 system
easy and cheap
Old Mar 27, 2007 | 09:41 AM
dgassett's Avatar
dgassett
That is why I ask. I really don't know what the po did to it. I find out as I go. it is a huge learning exp. for me. If I go to the junk yard, what should i be looking for? Pics would be nice
Old Mar 27, 2007 | 10:55 AM
Paul.Harrah's Avatar
Paul.Harrah
I am looking to upgrade my Dizzy to what is a ds2?
Old Mar 27, 2007 | 11:36 AM
LxMan1's Avatar
LxMan1
Duraspark II. It is the 70's and early 80's Ford electronic ignition with the brain box on the fenderwell.
Old Mar 27, 2007 | 11:38 AM
Paul.Harrah
Thank you. I have an 84 bronco with the eec that I want to get rid of. old california truck. Looking at installing a HEI.
Old Mar 27, 2007 | 04:43 PM
LxMan1's Avatar
LxMan1
Check out the DUI ignition. I am planning on installing mine this weekend in a 351W.
Old Mar 27, 2007 | 04:48 PM
Paul.Harrah
Ya I have looked at those but they are a little out of my price range I am looking at a Mallory 85 series HEI.
willsharps
40
Jul 16, 2012 07:01 PM
crakerjack51
Feb 23, 2008 04:33 PM
CATFORD
Oct 13, 2007 01:12 AM
ClatonK
Mar 8, 2007 07:48 PM
Rockledge
Electrical Systems/Wiring
Jun 11, 2003 08:31 PM
