speedo problem
Old Nov 3, 2013 | 01:51 AM
rockittsled's Avatar
rockittsled
speedo problem
speedo seems to be reading higher than it should be all of a sudden. no tach, but road noise to driving with traffic "ratio" what used to be a steady needle at 70mph now is 80-90mph that the needle floats (not bounces) between the two
Old Nov 3, 2013 | 08:51 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Could be it's time to clean and lube both the cable and the speedometer head.
The cable is easy, the speedometer, not so much. This usually involves disassembling the unit, cleaning out the 30+ years of crud then lubing everything up and put it back together.
Old Nov 4, 2013 | 02:45 AM
rockittsled
wish me luck that the panel doesn't crumble
Old Nov 4, 2013 | 04:35 AM
montana_highboy's Avatar
montana_highboy
That's like asking to touch the hand of god....
Those things always crumble at the slightest touch.
I think they changed the chemistry in the molds, after '80 it's not so "crumbly"
Old Nov 4, 2013 | 03:16 PM
Jdeshler's Avatar
Jdeshler
.. true Montana but I have been lucky 2 out of my 3 trucks.. but that one bad one was leaving crumbles in the floorboard way before I even pulled it out
Good luck rockittsled
1968bumpside
Mar 16, 2012 12:36 PM
alconk
Apr 18, 2009 11:33 PM
r_reed
Aug 10, 2008 11:01 AM
smaynor
Sep 2, 2003 08:42 PM
GammaDriver
Jul 4, 2002 09:59 AM
