egr help
Old Nov 2, 2013 | 07:46 PM
bballard1689's Avatar
bballard1689
egr help
I have a 91 f150 5.0 i got no vac to my egr. Im sure the solenoid is shot however i dont have much goin to it either so my question is can i run a fresh vac from my tree to the new solenoid and sole the problem.
Old Nov 3, 2013 | 07:12 AM
'89F2urd's Avatar
'89F2urd
do you have a vacuum tester? i'd never try to diagnose problems without one, all major auto part stores sell them. test the lines, be sure theyre at fault, and replace as necessary.
yes, you can run a new line from the tree to replace the faulty ones.
Old Nov 3, 2013 | 08:04 AM
subford's Avatar
subford
Note that there is no vacuum going to the EGR valve at idle, WOT and cold engine.
Old Nov 3, 2013 | 10:20 AM
bballard1689
Ok so no vac from the solenoid or to the solenoid and i have checked the lines and there good i have also put a very small amount of vac to the egr at idel and it reall smoothed it out
Old Nov 3, 2013 | 11:24 AM
subford's Avatar
subford
When you put vacuum on the EGR valve at idle the engine should run rough or die.
Old Nov 3, 2013 | 11:49 AM
Krisverde's Avatar
Krisverde
Do you have any codes?
Old Nov 3, 2013 | 04:47 PM
73 ford guy's Avatar
73 ford guy
I recently had this same issue! I did the same and ran a new vacuum line to the solenoid. Worked like a champ.
After I tee'd into the line to egr with a vacuum gauge running up to windshield under wiper and watched the vacuum kick in under cruise only after warming up as its suppose to function.
Old Nov 3, 2013 | 05:11 PM
Eddiec1564's Avatar
Eddiec1564
Here's some reading: https://www.ford-trucks.com/forums/1...-symptoms.html
EGR problems are occuring alot more as these vehicles age. Maybe a sticky about this up top of the forum??
James_24_85
16
Jan 1, 2015 08:41 PM
Thorntontribe
Nov 23, 2014 03:30 AM
MeanMark87
1997 - 2003 F150
Jun 14, 2014 09:58 PM
brassy
Jun 11, 2006 11:59 AM
muckypaws
1978 - 1996 Big Bronco
Dec 30, 2005 11:12 AM
