New pads and rotors still a horrible shutter what next?
As the title states I just finished putting pads and rotors on the front of my 04' f250. I have had a terrible shutter almost a bouncing effect while braking over the last week or so, finally got around to doing the work and still no satisfaction! My question is where to go next? Wheel bearings and tires are good, I do get a pretty good wobble/vibration in the pedal while braking. Should I be looking at a brake booster or master cylinder? Or is it possible it's a caliper? Truck goes down the road fine until and brake is applied. Any help would be greatly appreciated, thanks Adam.
Thanks for the responses guys. I guess I ruled out the back completely because all of the shuttering and shaking feels like its in the front, but I do have a pulse in the pedal so I'll look at the rears today. As far as calipers go the front compressed fine when I did them does that mean they are still good? I guess I've never seen a caliper go bad before, other than rotting out and starting to leak. What can you expect to see with bad calipers? Thanks again, Adam
lukedraper
1978 - 1996 Big Bronco
10-23-2005 11:18 AM
