1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
New pads and rotors still a horrible shutter what next?
Old 11-02-2013, 06:09 PM
Mazz's Avatar
Mazz
Mazz is offline
As the title states I just finished putting pads and rotors on the front of my 04' f250. I have had a terrible shutter almost a bouncing effect while braking over the last week or so, finally got around to doing the work and still no satisfaction! My question is where to go next? Wheel bearings and tires are good, I do get a pretty good wobble/vibration in the pedal while braking. Should I be looking at a brake booster or master cylinder? Or is it possible it's a caliper? Truck goes down the road fine until and brake is applied. Any help would be greatly appreciated, thanks Adam.
Old 11-02-2013, 07:32 PM
fairlane70's Avatar
fairlane70
fairlane70 is offline
It is always a good idea to make sure your calipers are not sticking. when i did my f350 I put all new calipers on. usually when you feel pulsation/vibration in brake pedal it is rear brake/rotors and if you feel it in steering wheel it is front brakes/rotors.
Old 11-02-2013, 08:32 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Agreed never rule out the rear brakes causing the issue..
Old 11-03-2013, 05:37 AM
Mazz's Avatar
Mazz
Mazz is offline
Thanks for the responses guys. I guess I ruled out the back completely because all of the shuttering and shaking feels like its in the front, but I do have a pulse in the pedal so I'll look at the rears today. As far as calipers go the front compressed fine when I did them does that mean they are still good? I guess I've never seen a caliper go bad before, other than rotting out and starting to leak. What can you expect to see with bad calipers? Thanks again, Adam
Old 11-03-2013, 06:27 AM
D-Ski's Avatar
D-Ski
D-Ski is offline
Not just the calipers but also the slide pins have to be working freely as well.
Just went through the same issue on my 05
fordmustangfan67
08-03-2015 08:54 PM
2track
2004 - 2008 F150
10-19-2011 08:29 PM
labman1014
08-28-2011 07:06 PM
jjpic
1997-2006 Expedition & Navigator
10-11-2007 11:16 AM
lukedraper
1978 - 1996 Big Bronco
10-23-2005 11:18 AM
Quick Reply: New pads and rotors still a horrible shutter what next?
