Sponsored by: Innova
Steering Wheel controls not working
Old Nov 2, 2013 | 03:38 PM
mlux2008's Avatar
mlux2008
Installed a new headunit into my 2006 F350 lariat.
Head unit is an Alpine INE-S920hd. It is connected to the PAC SWI-RC.
Connected all wires and soldered all connections. All features of the head unit appear to work correctly EXCEPT the steering wheel controls. I go through the steps/procedure to set the programing and the version. I'm using the white wire from the PAC and its connected to the blue/red wire on the truck wire harness. I go though the steps to program the controls.
When I go through to program the module it goes through the steps perfectly. All the lights flash as they should, I go to use the steering wheel controls and no response from the head unit.
When I press the volume up/down button the module blinks (as its suppose to), but no response from the head unit.
Any help would be appreciated. I reread the instructions and have done multiple installs just like this with no issues like this. Unsure what to do
Old Nov 2, 2013 | 07:32 PM
madsonp's Avatar
madsonp
Are you sure you have the PAC unit fully plugged in to the back of your head unit ?
Old Nov 3, 2013 | 01:55 AM
ItsMREMT's Avatar
ItsMREMT
Do you have the right PAC module?
Old Nov 3, 2013 | 02:29 PM
madsonp's Avatar
madsonp
If you do have everything hooked up correctly and it's fully plugged into the head unit and it's still not working correctly, give PAC tech services a call, they're very knowledgeable and good to work with.
Old Nov 5, 2013 | 02:31 PM
mlux2008's Avatar
mlux2008
Yes its fully plugged in and according to crutchfield it is suppose to work.
Old Nov 5, 2013 | 03:59 PM
madsonp's Avatar
madsonp
Well, then like I mentioned before, give PAC tech support a call.
Technical Support:
PHONE: 866-931-8021 (toll free in the U.S.)
727-572-9255 ext.230 (Customers Outside of the U.S.)
Mon-Thurs 9am-7pm EST
Friday 9am-6pm EST
Sat 9am - 7pm EST
Email
http://pac-audio.com/contact.aspx
Watcher58
Nov 25, 2015 11:19 AM
CountryD
42
Jan 7, 2013 06:18 PM
bullish4
Aug 5, 2006 09:47 PM
2DLAKE
Jan 20, 2006 11:21 AM
2DLAKE
Jan 20, 2006 11:18 AM
