A/C Delete Pulley Install Notes..
Old Oct 31, 2013 | 11:09 PM
gman97005's Avatar
gman97005
When installing the Dorman 34150 A/C delete pulley there are several extra parts in the bag including 3 long 3/8" O.D, sleeves, 3 short 3/8" O.D. sleeves, large thick washer,and a long metric bolt with a nut flange in the middle of it that doesn't fit anything. The sleeves are there because 2 of the holes in the delete bracket are larger than the supplied bolts, use 2 of the long or short sleeves and toss the rest aside, place the sleeve over the bolt and thread one into each of the 2 oversize holes, once the bolts are hand tight grab a ratchet with 13mm socket and crank them down, the sleeves will be sucked into the holes and all the slop will be gone, i used 2 of the longer sleeves. The large thick washer is there in case you have to shim the pulley away from the delete bracket, it was not required for my installation. The A/C compressor was heavier then i thought and was nice weight loss project, access and view to the front corner of the engine is greatly improved and valve cover removal is now possible, nice mod..
jerryst
Jul 12, 2018 02:19 PM
jerryst
Sep 25, 2016 09:24 AM
MyFX-4
2004 - 2008 F150
Mar 29, 2010 12:20 AM
FordPUs
Dec 14, 2005 02:32 PM
Rocking M
May 17, 2002 10:06 AM
