stumped
Old Sep 24, 2016 | 09:16 PM
jerryst's Avatar
jerryst
stumped
I am bolting on a bogerson double groove pulley on to my 1955 f100. The problem I am running into is when I bolt on the balancer bolt onto the pulley the pulley does not sit flush to the balancer. I thought bolting the balancer bolt and washer and then using two bolts to bolt on the pulley onto the balancer. Here is the rub the balancer washer is 1 and 3/4 in diameter. The bolts holes are 1 and 1/2 . The washer gets in the way of the bolts. Does anyone know if there is a smaller diameter balancer washer? I checked the pulley isnt hitting anything. Kind of stumped.
Thanks
Jerry
Old Sep 25, 2016 | 01:30 AM
Kurt G.'s Avatar
Kurt G.
Is it possible to grind the washer in those 2 places? does the new pulley have a sleeve or insert that engages the balancer center hole? if so is it the correct size?
Old Sep 25, 2016 | 01:51 AM
jerryst's Avatar
jerryst
I think its the right washer for the balancer bolt. Never thought grinding it. I was thinking of going to junkyard to look for a washer that would fit this dimension. As long as it fits bolt and small enough to fit between the two bolts I guess it would work. Maybe grinding will work.
Thanks
Jerry
Old Sep 25, 2016 | 07:39 AM
CharlieLed's Avatar
CharlieLed
I would be posing this question to Borgeson and see what they have to say about it. I have always gotten good customer support from them in the past.
Old Sep 25, 2016 | 08:14 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
I didn't want to say anything earlier but I had that problem with a bolt on I bought at a swap meet. You sounded as though yours worked and I just chalked my problem up to buying something you really weren't sure if it was right. Just a thought can you install the harmonic balancer & pulley on without the crank washer? Seems to me my bolt on was as thick as the washer where it bolted to the damper.
Old Sep 25, 2016 | 09:24 AM
artscott61's Avatar
artscott61
Veteran: Navy
Don't know for sure but you might try a SAE washer they also have extra thick
jerryst
Jul 12, 2018 02:19 PM
kopfenjager
13
Mar 21, 2015 10:50 PM
Payner44
Feb 15, 2008 06:35 AM
FordPUs
Dec 14, 2005 02:32 PM
