TAN VALVE
Old Oct 30, 2013 | 11:52 AM
lumberjack_964's Avatar
lumberjack_964
TAN VALVE
Hello all!
I own a '85 F-150 and I removed the engine(351W) so that I could replace the gaskets on the following: Oil pan, heads, intake manifold and water pump, along with replaceing the water pump itself. Everything went fairly smooth. However, when I popped one of the heads off I found this.
http://picture.vzw.com/mi/812014327_...border=1,0,0,0
can anyone tell me why only the one valve is tan?
Old Oct 30, 2013 | 12:46 PM
baddad457's Avatar
baddad457
Link doesn't work. The short answer is the mixture distribution is diffferent than all the other cylinders. Probably Nothing to worry about. Typical results for any engine, even EFI motors
Old Oct 30, 2013 | 12:58 PM
lumberjack_964
Sorry about the pic. Can you only upload pictures from the internet? how can I do it from my desktop? In the picture the rest of the combustion chamber is black from carbon except for the valve. even the other valve is black. that is ok?
Old Oct 31, 2013 | 11:14 PM
Beanscoot's Avatar
Beanscoot
Valve color
Typically the intake valves are black, whereas the exhausts are tan to white. This is because the exhaust valves run very hot, and burn off residue. The intakes are cooled by the incoming fuel so don't burn off the bit of combustion residue that condenses on them.
Old Nov 3, 2013 | 09:46 AM
Conanski's Avatar
Conanski
You only have 1 cylinder that runs correctly and the rest are fuel and/or oil soaked. If the motor runs fine don't worry about it.. it's a carb so there is no getting all cylinders to the exact right mixture, the best you could hope for is the outer cylinders at roughly ideal mix with the inner cylinders rich, and that's because of uneven airflow through the intake.
Acameron19
Engine Swaps
Sep 2, 2013 07:56 PM
mustang81
Mar 23, 2008 01:43 PM
MercM47
Jul 15, 2004 07:35 PM
MufassaMaxx
Aug 15, 2002 09:05 PM
ford_nut
May 1, 2002 09:28 AM
