UOA every oil change
Well my latest OC I had just received the report back and I have 3.5 fuel in the oil, so I am going to assume that the opposite bank now has a bad o-ring. It goes in next week to get diagnosed/repaired.
For the little bit of money it costs do have an UOA done it is well worth it in preventitive maintainance.
The sample was perfect other than the fuel contamination, FE was low and for some reason viscosity was a mid-range 30wt. (10w-30)
All-in-all, I agree that the UOA is a handy tool.
https://www.ford-trucks.com/forums/1...lter-post.html
I began doing some research and came up with this...
............. Plus 50 II ...... Delvac 1300Super ...Delo 400LE ....Rotella T5
VISCOSITY
@40C..............80.1.............79............. ......80...................78.9
@100C.............12.1.............12............. ......12...................12
VIS INDEX........133..............148................. .145.................147
POUR POINT.......-40..............-33..................-27................-42
FLASH POINT......223..............215..................2 04...............224
TBN...............10.5..............8.6........... .......8.7...................10
SULFATED ASH.......1................ .99.................1..................1
HTHS...............3.6..............3.6........... ......???..................3.5 (actual unknown but per API spec for grade)
I will get the UOA for the 5w40 and then again when I switch to T5 (or John Deere plus 50) I haven't decided yet...and compare the results and decide from there what to do next. I used Delo 15w40 (dino oil) and switched to Delvac 5w40 for this oil change. I never sent a sample to blackstone, but I ordered the test kit to send it in for this sample. I'm eventually looking to extend my Oil Change Interval (OCI) to 7500 mi.
Since July 29, I have put 8,900 miles on my truck. Averaging almost 3,000 miles per month. If Blackstone will tell me that I can extend my oil changes to 7,500 with syn blend, it will save me a good amount. T5 in it, that will save me $6.00 per gallon (about the same amount it costs to get the UOA) and as roadrunner already mentioned, it could save me even more by uncovering potential issues before they leave me stranded.
I switched to a highly recommended oil at around 10k miles on the odometer and at about 60k miles (10 oil changes) the lead values jumped up significantly - for several analyses. The oil (Schaeffers 9000) was not API certified, but they claimed it met or exceeded all of the API specifications. After I switched to Rotella T6, the lead numbers came down quickly. Since then, I have used Valvoline PBE, Mobil 1 5W40, and now Mobil Delvac 1 and the high lead numbers have not returned. Point being, conclusions often times should not be made on a few oil change analyses. It is great that people post up the oil anaysis results though - especially over a long period of time as Roadrunner has. That information is very useful and convincing.
So .... I want to first make sure that no one assumes that I am saying that the 10W30 is a bad oil. It seems to be working for quite a few folks. I plan to try it at some point in the future - probably after a fair trial of the Mobil Delvac 1 5W40 that I am currently using. I am still skeptical of the 10W30 in 100 degree heat when towing heavy loads, but that is for another discussion.
I will say that I am hesitant to use the John Deere Plus 50 II 10W30 oil since it is not API certified (according to a few internet forums). Clearly an oil does not have to have the certification to be good, but I am very curious as to why a company would not gain the certification. It simply is not all that much money (or at least it wasn't years ago when this topic had a lot of attention). After the Schaeffer experience, I decided to stick to API certified oils. Others will probably take a different position, and that is fine.
There are a few T5 10W30 threads here on FTE. They are all generally positive reports of it. If you can, give it a good workout - towing over 10k lbs in summer weather. A number of foks here would like to see the results I am sure.
By the way, I found this thread at the other site: What is a TBN?
6.0 oil analysis on Rotella T-5 10w-30. You will probably like this. - Ford Powerstroke Diesel Forum
As I remember there was a ton of information contained in that thread it was a very good read as it was posted.
Blackstone estimates fuel dilution from a flash point test. Other Labs use Gas Chromatography.
http://www.machinerylubrication.com/...l-diluents-oil
I have gone so far as to split samples between Blackstone and other labs and IMO the Blackstone fuel dilution number is not always reliable.
Here are good articles on proper oil sampling:
http://www.monition.com/pdf/oil-****...-procedure.pdf
http://www.technologylubricants.com/...0procedure.pdf
<TABLE style="WIDTH: 195pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=262 x:str><COLGROUP><COL style="WIDTH: 97pt; mso-width-source: userset; mso-width-alt: 4608" width=130><COL style="WIDTH: 49pt; mso-width-source: userset; mso-width-alt: 2332" span=2 width=66><TBODY><TR style="HEIGHT: 66pt" height=88><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 97pt; HEIGHT: 66pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl29 height=88 width=130></TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; WIDTH: 49pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl32 width=66>Blackstone
Schaeffer 9000
5W-40
</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; WIDTH: 49pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl31 width=66>Polaris
Schaeffer 9000
5W-40
</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl29 height=18>Oil Change Date</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: silver; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl33 align=right x:num="39702">9/11/2008</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: silver; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl33 align=right x:num="39702">9/11/2008</TD></TR><TR style="HEIGHT: 13.8pt" height=18><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.8pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl36 height=18>Oil change #</TD><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: silver; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl34>9th</TD><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: silver; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl34>9th</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 0.5pt solid" class=xl35 height=18>Aluminum</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 0.5pt solid" class=xl28 align=right x:num>3</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 0.5pt solid" class=xl27 align=right x:num>1</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Chromium</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>1</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>1</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Iron</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>26</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>24</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Copper</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>3</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>3</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Lead</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>7</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>6</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Tin</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>0</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>0</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Molybdenum</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>283</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>259</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Nickel</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>0</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>0</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Manganese</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>0</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>0</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Silver</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>0</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>0</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Titanium</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>0</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>0</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Potassium</TD><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 0.5pt solid" class=xl30 align=right x:num>3</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>1</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Boron</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>7</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>3</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Silicon</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>7</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>9</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Sodium</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>5</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>5</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Calcuim</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>3689</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>3400</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Magnesium</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>8</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>10</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Phosphorous</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>1312</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>1173</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Zinc</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>1453</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>1343</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Barium</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>0</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>0</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Vanadium</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24></TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>0</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Antimony</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24></TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>41</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>SUS vis at 210 F</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>69.6</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25></TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>cSt at 100 C</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>12.85</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 align=right x:num>13</TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Flashpoint</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>390</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25></TD></TR><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 13.2pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=18>Fuel</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: transparent; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 align=right x:num>2</TD><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext; BACKGROUND-COLOR: #ccffff; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25><0.5</TD></TR></TBODY></TABLE>
