E4OD remote filter Question
Old Aug 8, 2014 | 06:23 PM
eakermeld's Avatar
eakermeld
Originally Posted by mtcox
Eakermeld,
I'm not sure why it would matter. The technician at B & M wasn't clear about where in the system to put the filter. He didn't seem to understand how the fluid in an E4OD worked it's way around the radiator and cooler. When I asked him again to confirm, he appeared annoyed.
If anyone else has the directions, take a moment to read them. The directions come with the filer and they're available online. It's a difficult read and one of the instructions refers to a step that doesn't exist.
http://www.bmracing.com/bmnew/pdf/9500371.pdf
These instructions ARE quite confusing! I like how they tell you to skip steps and go to other steps and step 8 is "Go to step 14" which doesn't even exist!
Old Aug 8, 2014 | 06:24 PM
eakermeld's Avatar
eakermeld
I think I'd go with Krooser and put it after the final cooler. Good luck on the install!
Old Aug 14, 2014 | 09:36 AM
mtcox's Avatar
mtcox
Thank you for the confirmation that I wasn't crazy concerning the installation instructions. I plan on contacting B & M and asking them to review their own document.
I have a front mount hitch assembly and I can attach the filter assembly to the back side of the receiver. It's a good location to plumb the unit AFTER the radiator and cooler. It's also where Ford has a break in the hard line with a section of rubber hose. Cutting will not be necessary. I'll post pictures of the installed unit once I'm complete.
Briansshop,
Where did you find your flexible transmission lines?
Old Aug 14, 2014 | 12:52 PM
Evan_P's Avatar
Evan_P
Line like what Brian has have to be custom made.
As for the whole placement debate, flush the external cooler and radiator when you drain the trans. That's what I did with mine, then stuck the filter in before the cooler and radiator to prevent anything from building up in them.
Old Aug 14, 2014 | 08:42 PM
Briansshop's Avatar
Briansshop
Briansshop,
That's -6 size braided stainless steel hose with an alum fittings. You cut the hose to length and install the ends on it. Not hard to do.
Careful though, if you use that stuff, someone might accuse you of spending too much money on your own truck. LOL
Old Sep 19, 2014 | 09:26 AM
mtcox's Avatar
mtcox
I've installed the remote filter by B & M (no thanks to the instructions included with the kit). As you can see from the pictures, I've located it behind the front mount receiver. It's subject to stones or road debris but I'm hoping that the receiver deflects most of the fragments that may hit the front of the truck. It's located after the transmission cooler and before the fluid returns to the transmission. I loosened the output line from the cooler to swing and reposition it allowing a more relaxed loop of the rubber supply line into the filter. Other than that, no modifications were made. It's not pretty, but access to the filter will be easy. You'll need about two feet of 5/16" rubber line to complete the job. In addition, you'll need to buy the brass nipples that screw into the filter housing. The two included with the kit are too big for the 5/16" line.
Located behind the front mount receiver.
A view from the passenger side. It's mounted to the receiver with two stainless steel bolts.
A view from the ground looking up.
Old Sep 19, 2014 | 09:28 AM
mtcox's Avatar
mtcox
Old Sep 19, 2014 | 11:45 AM
dixie460's Avatar
dixie460
I can't believe y'all are taking the time and spending the money to protect your transmissions from damage, and then using FRAM filters which have been known to CAUSE damage.
Otherwise, everybody's install looks good!
Old Sep 20, 2014 | 04:14 PM
77_F150_4x4's Avatar
77_F150_4x4
I just put mine after the cooler, right hand frame rain between core support and crossmember. Runs a purolator(FL1A equivalent). Also did return side on my power steering, after the redhead box (not very impressed with them) went in, the saginaw didn't care but the old box was having internal issues.
I have been looking into other filter options though, apparently they make filters that are specifically for transmissions less restriction but price and numbers yet to be found.
Curtis
Old Sep 21, 2014 | 09:58 AM
FordTruckfan89's Avatar
FordTruckfan89
mounted mine on the core support. nothing wrong with a fram for transmission filter use. I usually change mine out every 3-5k. went back and used grade 8 bolts and lock nuts to fasten it to the core support.
Old Sep 21, 2014 | 11:25 AM
Island Time's Avatar
Island Time
Well at least you have an alternate location to hoist the truck from.
Old Sep 21, 2014 | 12:11 PM
FordTruckfan89
Better idea then using the sheet metal screws that the filter mount came with. I don't want it coming off or working loose.
Buck268
2009 - 2014 F150
Sep 23, 2016 10:35 AM
HT32BSX115
May 9, 2015 01:08 AM
MiamiPSD
Jan 26, 2010 05:40 PM
f150_514ci
Offroad & 4x4
Jul 6, 2005 04:39 AM
William
Mar 13, 2000 06:21 AM
