EXTERNAL TRANSMISSION FILTRATION
Old Jan 26, 2010 | 01:55 PM
MiamiPSD's Avatar
MiamiPSD
Need some help here. When I first purchased my truck I installed a magnadyne in-line transmission filter on the line going into the cooler. It was done this way since the truck was new. Now I want to install a after market spin on type filter and base like the DieselSites or SpringerPop's. My question is can I keep the madnadyne in place before the cooler and use the other after the cooler and going back into the transmission to get the best of the two, or is that too much back pressure on the transmission?
Should I use the spin on in place of the magnadyne or take off the magnadyne and install the new spin on after the cooler? Or leave thing's like they are?
The filter base set up I will be using is a Baldwin OB1318 (25 psi) with a Baldwin BT839 filter.
Will be making the installation in front of the truck somewhat like SpringerPop's has his.
Old Jan 26, 2010 | 02:46 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i would take off the magnefine filter and put on dieselsite's filter. it goes in the return line right where it goes back into the trans. i had one on my truck but took it off when i got the BTS.........
Old Jan 26, 2010 | 04:29 PM
MiamiPSD's Avatar
MiamiPSD
Bill, which one of the two did you take off and did you replace it with another style?
Old Jan 26, 2010 | 04:37 PM
indyF-350psd
my truck never had a magnefine on there but i put one of dieselsite's filter's on there. brian at BTS took it off for some reason he doesnt like them. i ended up putting it on my father in law's truck.......
Old Jan 26, 2010 | 04:43 PM
MiamiPSD's Avatar
MiamiPSD
Did BTS say why he didn't like them? Was it the extra load on the fluid?
Old Jan 26, 2010 | 05:05 PM
MiamiPSD's Avatar
MiamiPSD
WOW, where is all the help here guys? Anytime................. any thoughts?
Old Jan 26, 2010 | 05:40 PM
jt371's Avatar
jt371
______
Subscribing....... I have an magnefine filter to install when I add the extra cooler I have. But this also crossed my mine the other day if a spin on setup would be better.
creator
Oct 11, 2016 10:28 AM
2500ak
19
Oct 30, 2013 01:10 PM
99expyTN
Sep 20, 2013 04:00 PM
KJNDIVER
22
Jun 6, 2011 10:50 PM
SpringerPop
Apr 2, 2007 08:52 PM
