auto trans and idling issues.
when driving it you can hear the usuall ford ps pump whine, i think the pressure is low cause if you are on the brake and try to turn the wheal it is very stiff, but only when using the brake. wich brings me to my first question, when sitting at a stop light for a little while the rpms start to drop to around 450-500 then back up to around 800 or 900, then back down. it would only do this IN GEAR, NOT NEUTRAL OR PARK, and only with your foot on the brake. i ran a KOER test and get a trans code for p1746 "pressure control selenoid circuit open" (does shift hard). could the idle issue be from the trans, or maybe the low ps pressure? (or not related to either?)
the other codes that come up are
p0605 pcm internal rom error (mine does the same every test but nothing when driven)
p0470 exhaust pressure sensor circuit fault.(not too concernd about that right now, tube looks rusted)
any suggestions on this "pressure control solenoid", how hard to fix? and could this in any way be tied to the idle issue?
