ICP readings
Old Nov 8, 2010 | 10:33 PM
Speedjester's Avatar
Speedjester
ICP readings
Well was monitoring my icon pressure and noticed hot at. Idle it read between 590 and 586 is this normal... truck runs. Great no issues...
Old Nov 9, 2010 | 07:15 AM
Speedjester
Anyone have any thoughts..:
Old Nov 9, 2010 | 09:31 AM
High Binder's Avatar
High Binder
Hmm, my truck is at 630-640 at idle. I just put in a new sensor though and have no idea what it read before.
Old Nov 9, 2010 | 10:00 AM
dchamberlain's Avatar
dchamberlain
I assume you mean you're monitoring your Injector Control Pressure?
What are you monitoring it with? If it's with a Scan tool that reads active PID's, monitor the ICP compared the the Commanded ICP. They should be the same.
I'm not exactly sure of the names of these PID's, but you should be able to figure them out. There should be one for the actual Injector Control Pressure, and one for what the PCM is expecting.
Old Nov 9, 2010 | 10:22 AM
Speedjester
Not sure what else I can read... I'm using a scan gauge 2...
Old Nov 9, 2010 | 09:01 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Mine reads about the same. I have read somewhere that these would be considered normal.
tommyl
Sep 1, 2014 10:00 PM
Iaff113
Feb 27, 2014 05:15 PM
fordman1986xlt
Mar 3, 2013 04:25 PM
bluefin
6.7L Power Stroke Diesel
23
Apr 17, 2012 06:43 AM
wolfmanagh
Apr 29, 2011 06:56 AM
