Carburetor icing up
Old Oct 30, 2013 | 01:53 PM
Rmc292's Avatar
Rmc292
Carburetor icing up
What causes the carburetor to ice up. I have a Ford Holly 2 barrel (2110) and after about 1 min the carb will start to frost over. Anyone know what causes this?
Old Oct 30, 2013 | 02:41 PM
schoo's Avatar
schoo
has to do with the venturi effect when air passes through the carb it is passes from a large opening to a smaller and then gas is added causing more temp drop some engines use a carb heat from the exhaust man to carb almost all aircraft with carbs use carb heat
Old Oct 30, 2013 | 03:08 PM
schoo's Avatar
schoo
did you block the cross over on your in take manifold
Old Oct 30, 2013 | 04:12 PM
Y-Blockhead's Avatar
Y-Blockhead
Exactly what I was going to ask...
Old Oct 30, 2013 | 07:40 PM
Rmc292's Avatar
Rmc292
carburetor icing up
I guess I don't understand what you mean by blocking the cross over on the intake?
Old Oct 30, 2013 | 07:51 PM
Y-Blockhead
There is an exhaust passage that runs under the intake from one head to the other to warm the incoming gases. Some folks block/restrict it to prevent the intake paint from burning in that area or for perceived "high performance".
If you are unaware of it, you probably have not blocked it.
Old Oct 30, 2013 | 10:39 PM
Rmc292's Avatar
Rmc292
Carburetor icing up
Thanks, I have not block it. I'm running 292 with 3X2 I rejected the primary carb from 52 to 55 and the two secondary to 48 and that seems to fixed it.
Thanks again!
Old Nov 3, 2013 | 05:37 PM
312's Avatar
312
that would do nothing the weather changed and fixed it for now.it happends around the freezing point.the problem was solved in 57 when they hooked a heat passage to the breather which went to the exhaust manifold.
Old Nov 4, 2013 | 07:41 AM
Rmc292's Avatar
Rmc292
I have the heat passage and it was 60 degrees here when it started doing this. I have seen it happen like you mentioned before. I have a old Hot Rod magazine printed in 1957 and they talk about how to setup a 3x2 by jetting them properly. Any way, it's not doing it any more the outside temp is in the 50's Thanks,
Old Nov 5, 2013 | 04:34 AM
The Horvaths's Avatar
The Horvaths
Technically, it is related to dew point. It can happen on a warm summer day. I'm glad that you seem to have it under control. Did the article also mention carb icing? I'd be interested in reading that.
Old Dec 1, 2013 | 11:47 AM
vntgtrk's Avatar
vntgtrk
This is the closest answer. Usually carb icing will only happen when the temp is around freezing and the humidity is just so. Pilots will see this more often than those of us who are grounded. If you see carb icing on a V8, something is amiss. You're getting a lot of heat because of the carb being on top of a big heat pump.
http://en.wikipedia.org/wiki/Carburetor_icing
68cabby
Dec 10, 2012 03:48 AM
69taposer
Jun 23, 2012 05:31 AM
johnnyg
Apr 15, 2010 06:02 PM
partsman01
Jun 23, 2007 12:49 AM
jzjames
13
Jan 18, 2005 04:10 AM
