Looking for Clear Answer On Doorman Oil Cooler
Old 01-27-2014, 10:54 AM
Carolina Rig's Avatar
Carolina Rig
Carolina Rig is offline
Originally Posted by bismic
who would want to be the next guinea pig!!??
That's the truth!! I feel like a total chump for ever installing that crap. I ignored the gut feeling telling me it was a bad idea.
Dan
  #32
Old 01-27-2014, 11:29 AM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
Originally Posted by Carolina Rig
I posted an earlier response to the Dorman oil cooler question, and my initial response was dead wrong.
THEY ARE F*****G GARBAGE!!
Without going into any details about symptons, here's the 10K mile update:
Hope this clears it up for everyone.
Nothing got past the sump screen under the cooler. IPR screen was clean; however oil and coolant mixed.
As a mechanical engineer myself for over 25 years, what's every bit as important as mechanical fitment is material selection. Dorman severely failed in perhaps the most fundamental aspect of the design, and in perhaps the least expensive part of the manufacturing process.
I have the Motorcraft oil cooler in now, along with 8 new motorcraft injectors which I planned to do this winter.
Truck is running great.
There you go Troy....he owned it, touched it, used it....unfortunately he had to touch it again to remove the POS.
  #33
Old 01-27-2014, 01:41 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
Iv been Looking for this thread
All I can figure is Dorman didn't understand the Oil Cooler and they thought that particular seal was for Coolant Not Oil
So with Josh Pictures I guess its safe to Assume the symbol on the bottom of the oil cooler is a Dorman Symbol. Someone thought that VR may have had some oil coolers out there was why I wondered
  #34
Old 01-27-2014, 01:46 PM
BLADE35's Avatar
BLADE35
I hear that they have now changed the gasket material, but who would want to be the next guinea pig!!??
I think Anthony has been changing the gaskets to FORD and reusing the Dorman coolers on a few trucks the owners could Not afford a OEM Cooler at that time
I guess will see
at this point the price difference isn't worth the risk
  #35
Old 01-27-2014, 03:26 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
That little not so expensive part can take down the whole system.
This has become a very big problem when someone uses the wrong material for a part
to save a few ¢ on a project or is just greedy and subtitles a non approved part for lets
say an aircraft used in the military. That last one did happen. Contractor used a really
cheap seal in place of a very expensive one to supply for helicopter transmissions. It
was not holding up to what it was exposed to.
So what was learned from that? Know your souse and don't buy critical parts from
unknown souses
BTW they busted the contract supplier and now he (at least I hope) he is making big rocks into
little rocks. But sadly most likely he is still selling to government contract jobs.
But back to the main point. A little thing like a 50¢ seal can take out an expensive project.
Think what would of happened had this been a space suit. Or your space suit!
Sean
  #36
Old 01-28-2014, 12:02 AM
run6.0run's Avatar
run6.0run
run6.0run is offline
Originally Posted by run6.0run
That's funny,,, Good luck getting me to put it in. Lol
Oh boy,,, hindsight is a ****** huh???
Ok,, I've actually only reused a dorman cooler on Val n Shannon's truck. The last one I did talk the customer out of reusing it. It's very easy to suggest stuff when it isn't my money,, but I can't give stuff away. Best I can do is educate them as best I can.
  #37
Old 01-28-2014, 07:39 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Seeing that HPOP reservoir literally made my stomach turn! Damn!
Josh
  #38
Old 01-28-2014, 10:43 AM
Carolina Rig
Sean
It happens. I suppose I'm glad I wasn't trying to get into space:
Morton-Thiokol,1986: An O-ring fault in an MTI SRB http://en.wikipedia.org/wiki/Space_Shuttle_Challenger_disaster http://en.wikipedia.org/wiki/STS-51-L in flight. The company is found at fault for the destruction of the Challenger and deaths of the astronauts
  #39
Old 01-28-2014, 10:52 AM
Bullitt390's Avatar
Bullitt390
The Challenger disaster was more a breakdown in communication than a savings in money
Josh
LONCO
02-01-2019 09:19 PM
JohnInCanada
08-07-2014 07:49 PM
BryanStein
07-27-2013 01:52 PM
DawnPatrol
03-07-2013 08:47 PM
mottrocks
06-10-2010 07:38 PM
Quick Reply: Looking for Clear Answer On Doorman Oil Cooler
